slodave's Avatar
Distributor cap. Time to replace?
Hi!
I have posted in another thread about my engine problem suddenly dying/hesitating, but the thread really is not getting much attention. So, while trying to figure out my problem and since I cannot simply buy a new set of plug wires due to job issues, I decided to pull the cap.
All six points(?) looked the same. Looks like carbon build up. I carefully took some fine sand paper and tried to clean each point. They are cleaner, but looks like they are pitted. The rotor arm had some build up as well that I cleaned up, but looks fine otherwise.
Thanks for any input!
Dave
EDIT: I forgot to do a search first. And, I spelled Distributor wrong
Old 02-24-2007, 05:53 PM
Make Bruins Great Again
Por_sha911's Avatar
How many miles/years since you replaced the cap?
Joe
Old 02-24-2007, 06:53 PM
slodave's Avatar
Looks like it was replaced 2/91 at 93493 miles. My dad kept all receipts and I have done the same. Car now has 224,500 miles.
Dave
Old 02-24-2007, 07:09 PM
Immature Member
dentist90's Avatar
Just looking at the pitting of the contacts and the apparent heat damage around the inside of the cap tells me it's time for a new one. The mileage confirms it. You can make the contacts look shiny again, but the gap between the rotor and distributor will increase possibly leading to poor spark and greater chance of arcing to ground inside the distributor.
I read your post about the engine cutting out intermittently and I don't know that this would be the cause, although it's possible. In my limited experience when I have had bad arcing wires or worn distributor cap the symptoms were misfiring under load and at higher rpms. My cars have not outright stalled though.
For what it's worth, the only time my 911 stalled I traced the problem down to a loose battery connection on the + terminal. Only clue I had to this was that one time it did it for long enough for me to notice that the starter didn't work and none of the accessories were on.
Intermittent failures are the mother of all automotive headaches ( that, and a lack of $$ ) Good luck!
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 02-24-2007, 07:28 PM
Por_sha911's Avatar
You are way overdue for a cap and rotor replacement. The picture you posted looked pretty bad but I figured I'd ask since sometimes pictures can deceive if the the lighting and angle are wrong. I suspect that a set of wires would help but if you don't have the $ for them you still need a cap and rotor. Have you checked for arcing at night?
Joe
Old 02-24-2007, 07:37 PM
Jascha's Avatar
You might try using an old trick of spraying a mist of water (in a darkened garage) and see what sorts of ‘fire-works’ are creating havok...
That will tell you grossly something about the condition/location of the aging spark plug wires, distributor cap, etc…
1995 993 ('Under my Care')
1989 911 ('Go Pitt')
1996 993 ('Go Navy')
1984 911 ('Go Pelican')
Old 02-24-2007, 07:41 PM
Early_S_Man's Avatar
Porsche Crest
Dave,
That isn't carbon build-up inside the cap at the contacts ... it is erosion, and from that receipt date, yes, the cap needs to be replaced!
Your spark plug wires can be rebuilt -- just replacing the cable with bulk wire from a parts store, hotrod shop, bike shop, etc.
All that is needed is 14 M3 crimp connectors,and aboout 25 feet of bulk 7 mm spark plug cable. The new M3 crimp ends are available at Porsche and Mercedes dealers, and can be crimped by them, sometimes as a courtesy.
Here is a document showing installation details:
http://www.beru.com/download/produkte/TI05_e.pdf
Just to update for any that plan this wire replacement ... the M3 crimp-on ends are pn 911.609.310.00 from the Dec. '95 edition of the Parts and Technical Reference Catalog!
911-609-310-00-OEM Cable Screw for Spark Plug Tube Connection, 911 (1990-98) $1.50
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-24-2007, 07:45 PM
the the is offline
I've always had caps on my DME cars go a long time, and I think people generally replace them needlessly early . . . but 130,000 miles is a long time!
Old 02-24-2007, 07:52 PM
slodave's Avatar
dentist90: Just trying to rule out the possibilities. When the old wires were arcing (and I have no idea for how long) I did not have my current problem. There really wasn't a problem, other than the wires were old, arcing and needed replacing. Positive cable is still taped up with duct tape from track day back in December. Negative is not. I can check tightness tomorrow.
Joe: No, not at night. Arcing makes a distinct sound and I have not heard it while poking around during the day. I will check tomorrow night though.
Jascha: I'll keep that as a last resort for now...
Warren: The current plug wires are Jacobs Energy Core. 8.5mm I replaced them long before joining here. Probably better to just replace them. Thanks for correcting me on the carbon v erosion.
BTW, The first time I started the car after taking the cap off, no problems, but I only let it run for a few seconds. Second time about an hour latter, the car started, but tach bounced about four times - engine idle followed, then went back to normal. Only other time that has happened, was at TRE, when they did the compression test. Then it bounced until they shut it off.
EDIT: I will order up a new cap ASAP, but the wires might have to wait a little longer. Sigh.... Thanks!!!
Dave
Old 02-24-2007, 08:00 PM
slodave's Avatar
My dad never replaced things early. Slowly I am replacing most of the parts that are long time over do. I would replace everything at once, but don't have the means. So, if it ain't broke or life threatening, it will get a few move miles.
Old 02-24-2007, 08:03 PM
Por_sha911's Avatar
Dave: Change out the cap and rotor. Oil your distributor while they are off (do a search-its very easy). Start the car up at night and check for arcing with a fine mist of water (plant sprayer). If you have a bouncing tach, you may have a alternator/charging issue.
Joe
Old 02-24-2007, 08:07 PM
slodave's Avatar
Will do. The engine and tach were reving/bouncing in sync. Both times this happened was after the plug wires were touched.
Old 02-24-2007, 08:13 PM
durn for'ner
livi's Avatar
Dave,
When I serviced mine last summer, I changed the dist. cap and rotor among other things. They looked almost new, but I changed them regardless.
If not else, to be able to tell my tech imbecile academic doc colleagues that I have changed dist cap and rotor in my Porsche - all by myself..
I am still committed to make a silly impression on my Pelican fellow tech experts.
Markus
Resident Fluffer
Carrera '85
Old 02-25-2007, 01:46 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Yup...ready to be replaced...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 02-25-2007, 05:06 AM
Do you need the Beru tool or will a generic crimp tool work?
For the Pin I could see the generic working but what about the insulation crimp? Almost like a coax connector.
Old 02-25-2007, 10:39 AM
Autodidactic user
David E. Clark's Avatar
Dave
Pelican sells your distributor cap for $13.00. At the rate you're going, that's about 81 cents a year! Who says Porsche maintenance is expensive!
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 02-25-2007, 12:44 PM
Porsche Crest
rick-l,
I believe you need that specialized crimping tool. They are available, though pricey. Certainly no Pelican without a shop would need one.
Many have said that Mercedes dealer service people will crimp for free after purchasing the M3 connectors. If you already had the bulk cable cut to lengths ...
The M3 screw part is 911.609.310.00 and is available at Mercedes or Porsche dealers, and the dealer can crimp the new one back on the wire! The Mercedes pn for the crimp on plug connector ends is 000.159.1438.
Warren Hall, Jr.
Old 02-25-2007, 01:14 PM
defcon65's Avatar
Early S Man: Any spec on that 7mm cable you refer to? Will most parts stores have it, is there a certain brand name to ask for, is there junk to avoid? Having priced the wire sets at a couple places, this looks cheap by comparison. Are the plug and dist ends available as a separate part no.? Thanks, Joe
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 02-26-2007, 02:06 PM
Jascha's Avatar
Dave,
If you like, I will be glad to send you a used Bosch (~30K miles) distributor cap from my now gone (run over by an SUV) ’85 Targa.
I also keep a full set of back-up Beru wires that you can borrow to trouble shoot your electrical gremlins …
Old 02-26-2007, 07:22 PM
slodave's Avatar
Update:
I drove the car Sunday, up on Mulholland and not one problem. I ordered an new Dist. cap and rotor from Pelican and it should be here tomorrow or the next day. Yeah, I really could route the $70.- elsewhere, but I really felt better replacing them with new.
As for the plug wires, I will see what happens with the new cap and rotor. I will replace the wires, but, not now.
Jascha: Thanks for the offer. We'll see how things go for now. I will keep your offer in mind. Sorry about your '85.
Dave
Old 02-26-2007, 09:37 PM
