Need some Help
Well i just installed the front oil cooler scoop that goes where the light is in the bumper. My question is what do i do with the light, meaning the wiring. do i cut it or will it screw up all the other lights? Next is i installed solid Tanny mounts, i heard this is a bad idea, meaning lots of noise and vibration is this true. Thanks so much for your time.
“Well i just installed the front oil cooler scoop that goes where the light is in the bumper. My question is what do i do with the light, meaning the wiring. do i cut it or will it screw up all the other lights? ”
No problem. On earlier cars (pre- ’69?) it will effect the turn signal. The solution is to attach a bare bulb somewhere insulated. “Next is i installed solid Tanny mounts, i heard this is a bad idea, meaning lots of noise and vibration is this true.” I haven’t herd of a problem. I would chose to leave the engine mounts soft rubber. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
