e p slick's Avatar
930 rotor machining question
What is recommended minimum thickness for front and rear 1979 930 rotor thichness after machining? Thanks.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-12-2007, 06:17 AM
Bill Verburg's Avatar
30.6/26.6 mm
Bill Verburg
Old 03-12-2007, 06:19 AM
wcc wcc is offline
wcc's Avatar
Are those numbers the same for all 930 thru '89? Just curious cause I may have to do this to my '87 930.
Bill
997.2
Old 03-12-2007, 07:50 AM
yes
Bill Verburg
Old 03-12-2007, 08:14 AM
wcc wcc is offline
wcc's Avatar
Thanks Bill!
Bill
997.2
Old 03-12-2007, 08:18 AM
Somatic Negative Optimist
Gunter's Avatar
Make sure that an equal amount is taken off on both sides so the rotors stay centered in the calipers.
Also, after machining, install and check the runout with a dial indicator.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-12-2007, 08:41 AM
