Need a picture of Turbo twist wheels on 911
Does anyone have a picture of a 911 with turbo twists on it?
Thinking about getting a second set of rims around for my 87 and I'm thinking cups or turbo twists. Would be open to other options as well. Thanks Brian
1987 911 Coupe-Current ride 2007 997TT-Sold 2006 997 C2S-Sold 1991 964 Turbo-Sold 1987 911 Targa-You never forget your first |
how about this!!!!
before After
1989 C4 Coupe 1975 911 carrera 2.7rs Sold 1978 911sc Sold 2001 Boxster S |
Here is a picture of my car with Turbo Twists on it.
1996 Porsche 911 2013 BMW 335xi - Wifes car 2007 4Runner - 4x4 for Colorado snow Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe |
Red
Those look nice. I have my original Fuchs still, but have to admit that these look nice. Do they fit on without modification on say an '87 911 or what?
Thanks, Patrick |
Personally I like the cups better than the twists...but the twists were available cheap and I wanted to get more meat on the ground.
Real cups or twists require a 1 1/2 adapter on the rear and a 1 inch on the fronts. There are some aftermarket cup I's available in sc/Carrera offset but they are pretty heavy. |
Here they are on a 89 cab
steve
1982 SC |
Keep in mind you're seeing two examples of cars with Turbo Twists and two examples of cars with Boxster twists. Personally, I like the Boxster twist wheels because they have some curve to their profile, where the Turbo Twists are very flat. Just my opin, of course.
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
Administrator
You need spacers (with much longer studs) or adapters (with their second set of studs) to run the later-offset wheels, which would make switching back to the Fuchs a fairly complicated endeavor. If you want to switch two wheel sets back and forth, you'll be happier if you get wheels with the same offset.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Thanks for the pictures, the spacer issue is something that has always confused me. I've read a lot of posts in regards to them and still do not really understand what I need.
If I understand correctly the aftermarket wheels have a different offset that probably would not require spacers and late model OEM wheels require them? What offset we talking about? The distance measured from the back side of the rim to the face that mounts to the rotor? I have no idea what I'm talking about. Anyone have a picture of a spacer mounted to the rotor? Might help me understand what they do and how they work. Thanks guys Brian
1987 911 Coupe-Current ride 2007 997TT-Sold 2006 997 C2S-Sold 1991 964 Turbo-Sold 1987 911 Targa-You never forget your first Last edited by zbph10; 03-17-2007 at 04:25 PM.. |
RETIRED
Typically, one inch up front and two in the rear will allow for the use of many late offset on an SC or a Carrera. At least that's what the late 16x7 and 16x9 off of a 964 took for MY SC.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
84 911 Euro 3.6 liter |
Crotchety Old Bastard
Here is a picture of adapters bolted to a hub.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Another view, rear
Bland
I want to chime in on this.
I have 17" ROH's on my 77 widebody and just bought 18" Turbo Twists for it (They are at the shop awaiting rubber). The 17's are installed with spacers and work OK. When I aquired my 71 Tub (with rear suspension), I bolted the rear wheels from my 17 on to it to wheel it around and it worked OK - no spacers. Agreed, the suspension was at max travel (no motor) but I was surprised that they wouldfit under the rear fenders. Comments?
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Not to hi-jack the thread, but...does anyone know if the TurboTwists are directional? Looking at the above pics, I'd say yes, but I've seen pics of other cars with one side having the wheels "backwards".
![]() I'd love to get a set, but only if directional... ??? Last edited by Danny_Ocean; 03-23-2007 at 10:58 PM.. |
Bland
nope. not directional. the ones above that are must be the boxster wheels.
I've gone the opposite way from original teledials to twists and now Fuchs. The pictures below span about four years the oldest at the top.
What about wide Fuchs instead of the cups, perhaps 9"s on the back?
another round please
Here's pic of my 86 with TT's. I have to run adapters on it. These came off a 996.
Getting old is not for wimps. |
Back in New England!
Guys here are my 993 turbo twists on my 911.
I have a hub adapter on the rear just like Rarly8's. A bit of warning though, I just got back from a first rate shop (Performance Art) and their Porsche tech (with over 35 years experience) told me that adapter set-up is a safety concern on a driven axel. He told me that you need to go with a plain spacer and longer studs. I just wanted to mention that. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
