Bye, Bye.
Scooter's Avatar
No. We have run into some suspension issues. We are going to have to make some necessary modifications, which will take about 3 weeks. I will however, be able to drive the car in the interim. I pick her up tonight.
Elvis has left the building.
Old 04-04-2007, 09:10 AM
Light,Nimble,Uncivilized
Why so secretive? What is the nature of the suspension issuse(s)?
As you know I'm doing a similar set up on my car and I'd like to avoid any pitfalls, if I can.
Drago
'69 Coupe
R #464
Old 04-04-2007, 10:01 AM
Originally posted by Drago
Why so secretive?
If he told you he would have to kill you. I have his secrets, however, and I can be bought. Cheap.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 04-04-2007, 10:21 AM
Jamie79SC's Avatar
Jeff,
I'll buy your greasy breakfast next week, so consider yourself bought - spill it.
Jamie79SC
Old 04-04-2007, 10:40 AM
I'll buy you a bottle of your favorite Irish Whiskey to go along with Jamie's generous greasy breakfast offer. Spill it.
No holding out either.
I have Bernie's number and I'm not afraid to use it!
Drago
'69 Coupe
R #464
Old 04-04-2007, 11:00 AM
DW SD's Avatar
Just curious, what happened? I hope Island doesn't step in and say I told you so. That would be a shame, given his relentless hammering on the suspension choices.
If a mistake was made, let's share the info so others don't fall victim to the same issue.
Do the shocks need revalving / rebuilding?
Either way, I wish you the best in resolving.
Doug
1971 RSR - interpretation
Old 04-04-2007, 12:01 PM
Bye, Bye.
Scooter's Avatar
I am not trying to keep anything a secret, just haven't had time for the write-up.
The suspension problem has nothing to do with torsion bars, so we can ignore that debate for the time being.
The problem is with the front struts. I think there are a lot of cars out there with the same problem. I want my car at a certain height, but the shocks don't have enough travel, so I am riding on the rubber stoppers. I need at least 2" of travel, but I only have 3/4". The answer is to install raised spindles. I cannot have my struts (Koni) raised enough for my 2" travel (can only get 19mm), so I am likely going to switch my suspension to Bilstein and have my spindles raised by Clint, giving me more than enough travel. Alternative is to run Smart Racing RSR type raised spindles. I am looking at another alternative at the moment, but won't disclose that just yet.
I did my research before this project, but was not prepared for my research subjects to be incomplete or even wrong. Given my discussions with many well-known suspension experts, it sounds like there are a lot of people potentially running their cars without enough suspension travel.
Old 04-04-2007, 12:15 PM
Jamie79SC's Avatar
Jeff,
Since you were too slow on the come back, Scooter gets your breakfast.
Jamie79SC
Old 04-04-2007, 12:21 PM
DW SD's Avatar
Good move. Clint is a great resource.
I raised my Bilstein front struts 30mm to regain the travel, but I have 17" Lindsey wheels.
good luck,
Doug
Old 04-04-2007, 12:22 PM
Ira Ramin's Avatar
Scooter,
You’re right, I had the same problem and ran that way for a while without knowing it. The Koni’s are a little longer than Bilstein’s in both the front and back. Switching from Koni to Bilstein with raised spindles solved most of the problem for me. I still needed to raise the car back up a little. Clint will do a good job on your struts.
Ira
Tarett Engineering
Old 04-04-2007, 12:30 PM
Registered Cruiser
jorian's Avatar
Scooter,
How did you measure your suspension travel? Is that why you ran the struts/shocks without the dust covers?
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 04-04-2007, 01:01 PM
Originally posted by Scooter
I am not trying to keep anything a secret....
....but won't disclose that just yet.
Drago
'69 Coupe
R #464
Old 04-04-2007, 04:26 PM
efhughes3's Avatar
Wow Scooter, you didn't waste any time jumping into this one. Very nice!
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-04-2007, 04:34 PM
Bye, Bye.
Scooter's Avatar
Not running the front dust covers helps with determining the travel. Basically, you attach a zip tie to the shaft and bounce the car up and down and see where the zip tie ends up. My zip tie ends up 3/4 of an inch away from the rubber bumpers. I should be 2" from the rubber bumpers.
Bye, Bye.
Scooter's Avatar
Oh, going to pick the car up now.
Old 04-04-2007, 04:35 PM
Bouncing the car up and down?
My bouncing is different than say, Lori's bouncing.
I would think driving it would be a better test, especially out where his shop is. They've not paved the golf course road out there since before Higgins was born.
Drago
'69 Coupe
R #464
Old 04-05-2007, 06:49 AM
Bye, Bye.
Scooter's Avatar
Bouncing it up and down gives you a sense of how much travel is used on smooth roads, then you look to see how much travel is left for the bigger bumps. I can tell you that 3/4" is definitely not enough.
Old 04-05-2007, 07:14 AM
Somatic Negative Optimist
Gunter's Avatar
Hm............Bouncing a new strut or shock will not get maximum travel.
It's too stiff unless you weigh 500 plus lbs.
I remember checking the travel on my gas-pressured Bilsteins like this:
Before installing, measure from center mounting hole on the bottom to the top of the shock tower.
Then compress the shock completely and tie it compressed.
Measure and compare. That'll indicate how much travel you have.
I ended up cutting off 2/3 of the snubbers.
A lot of people are driving around way too low bottoming out and wondering where that "Park-bench feeling" comes from.
Raised spindles is the optimum way to go for people with money; I am just a poor pensioner.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-05-2007, 08:30 AM
I'm not even going to touch this one!
Can't wait to see her Scott. Say, does your drivers seat move fore and aft at all? Like, way aft?
Drago
'69 Coupe
R #464
Old 04-05-2007, 08:35 AM
Bye, Bye.
Scooter's Avatar
I'm going with Bernie on his method of checking to see if there is enough travel. I trust his judgment and expertise. We also talked about cutting the rubber bumpers, but was advised that the two bumpers are there to protect the shock from blowing out. If you go less than two then there is no protection from over-compression. This, of course, if for Koni shocks. I also considered Snubbers (a Koni product), but that is probably only a temporary solution. Raised spindles cost between $250 and $300, so I don't think it is too expensive of a proposition.
I just talked to Clint on the phone. What a great guy, very informed. I am now looking for '78 or newer Bilstein strut housings.
Old 04-05-2007, 09:14 AM
