Oracle's Avatar
Question Can I move the car without muffler?
Maybe dumb question but I rather be on the safe side...
While trying to replace the O2 sensor from hell (It's been soaking on liquid wrench all day and still not loose ) I took the cat converter out.
But looks like I'll need to move the car to the other side of the garage.
Is that okay?
Won't damage anything?
Since the O2 sensor is disconnected will that have any effect?
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 05-04-2007, 04:27 PM
Friend of Warren
Won't hurt anything and it will sound cool!
Kurt V
Old 05-04-2007, 04:44 PM
just do it quick and dont rev it up or you will probrobly set fire to somthing
Old 05-04-2007, 04:59 PM
RichF's Avatar
what about if you had took the headers off too and had no exhuast system on? Sorry to highjack but I have been wondering the same thing to.
"Work harder........... Millions on welfare depend on you"
" If you aint cheaten you aint tryin"
Old 05-04-2007, 05:15 PM
LakeCleElum's Avatar
You'll it so well w/o a muffler, you won't want to put it back on...Don't do it w/o headers; it's a good way to damage a valve. Hot exhaust valves don't like the cold air...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-04-2007, 05:21 PM
Bland
unclebilly's Avatar
Gaspar,
I was tempted to fire up my c4 with the cat off too but the battery was dead from leaving the hood open...
I'll bring your diagnostic tool back today.
Scott.
Old 05-05-2007, 07:15 AM
rnln's Avatar
yes, you can.
without muffler/cat. yes, there is header.
http://loveporsche.dynalias.com/cars/240z/Movies/240z-71-02-After-2-DaysCare.MPG
Fat butt 911, 1987
Old 05-06-2007, 05:13 PM
Bad idea to take the headers off, though I realize the poster was just joking. You need at least some hot metal between the valves and a rush of cold air when you shut the engine down. But then a lot of very powerful airplanes with Merlin, Allison, Wright and Pratt engines fly with stub exhausts, one per cylinder. So you'll be fine with the headers on. Hell, take it around the block...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-06-2007, 06:04 PM
Navin Johnson
TimT's Avatar
More popcorn!!!!
'69 911 GT-5
'75 914 GT-3
and others
Old 05-06-2007, 06:23 PM
Re: Can I move the car without muffler?
Free the sensor with a breaker bar.
Old 05-06-2007, 06:49 PM
Oracle's Avatar
Thanks you all for your input.
3 days took me to undo that O2 sensor:
Day 1 I used the special socket for this task and the impact wrench, about 650 ft/lbs of torque so the socket was just expanding and started to round off the edges..
Day 2 more liquid wrench and a visit to home depot for a long wrench and a propane kit
Day 3 Using the extra long wrench and a hammer the bugger came off
So all is good but I didn't get to hear the engine without the muffler...
ps. I'll return the propane and buy MAP just in case...
-Oscar Wilde
Old 05-06-2007, 09:36 PM
When you put the sensor back in, coat the threads with anti-seize compound and it will come out easily next time. Wurth makes some of the best--a light grease thoroughly impregnated with microscopic copper particles. Their Cu-1200 is intended for very high-temp applications like this.
Stephan Wilkinson
Old 05-07-2007, 06:49 AM
Oracle's Avatar
Steve,
The new O2 sensor came with anti-seize on the threads. I'm glad cause I found I don't have any and everything is closed around here after 4:00 PM
Maybe Bosch realized it was just smart to put the anti-seize and save the mechanics from getting hernias or worse..
-Oscar Wilde
Old 05-07-2007, 08:26 AM
Automotive Monomaniac
Emission's Avatar
+1
I used the "silver-colored" (graphite-based?) anti-seize for years.
When I put my exhaust back together, someone suggested the higher-temp stuff with the copper particles. It works very well, even in extreme-heat environments.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-07-2007, 08:59 AM
tedder's Avatar
back in the day, when my first car's muffler fell off it sounded sooooo cool...
Oh yeah, it was a 1300cc 1977 Honda Civic. Only ever sounded cool with no muffler.
08 Porsche Cayman (base) <- My hands are too big to need to compensate with an S
86 911 Coupe <- WOOT <- sadly gone since late 2014
Old 05-07-2007, 03:07 PM
