New distributor Engine won't start!
Good Morning.
I installed a new distributor in a 2.7, and replaced the points with the ignitorII. Once finished, I tried to start the car. It turns over but won't start. So I did the the installation procedure again but it still wouldn't start. I took the wire from the coil off to see if there is fire. Nothing. Any ideas? Thanks. Daniel |
Go back to your points.
Meanwhile, let's go over the installation instructions for the Ignitor. Joe Last edited by stlrj; 05-27-2007 at 06:25 AM.. |
Bland
Did you install your wires in the clockwise or anti clockwise direction? If you followed the Bentley manual, they are instaled backwards because the dist on SCs turns the opposite direction to a 2.7.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
http://www.pertronix.com/tech_support/assets/Porsche_CD_diagram.pdf
1. The red wire from the CDI (B) connects to the Ignitor Red wire. This is +12V from the ignition switch. 2. The CDI (A) connection goes to the positive side of the coil. This was the same wire originally connected to the positive side of the coil. 3. The Pertronix black wire connects to the negative side of the coil, and to a ground wire. Also make sure the magnet is going all the way down on the distributor. Measure how the rotor fits without the magnet on the distributor, then measure the rotor with the magnet on there. If the magnet is not seating all the way, you'll have to take a small file and remove a small amount of material from the six flats inside the magnet. It doesn't take much material removal - so go easy.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Thanks for the replys.
Unclebilly,I instaled the wires anticlockwise. Rex I did the installation the way you discribe it. The magnet fits all the way. I will try again. Thanks. Daniel |
