twobone's Avatar
Does this tail look right?
Its a ROW 87' coupe
The Carrera script is set to high, no?
Is a Carrera script attached with a push rivet or is it "stuck on"
Can it be moved?
Garage is empty
Gone:96 TVR Chimaera, 05' Mazdaspeed MX5/89' Caterham Super Seven/84' Carrera/81' 911 SC targa/74' MGB
Old 07-05-2007, 05:08 PM
Way too high. Stuck on with an adhesive, so it can be removed. Buy a new one; they're cheap.
JR
Old 07-05-2007, 06:14 PM
wow that looks weird i wonder why they put it there. Did they put that tail over the stock grille maby?
Old 07-05-2007, 06:21 PM
deshetlr's Avatar
script is to high. May have been left in place when the wing was attached. Great looking wing. Should be stuck on. Check the underside to make sure, Remove and leave clean or check the threads on this board for proper placement of the script.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 07-05-2007, 08:17 PM
Bill Douglas's Avatar
If it is stuck on get onto it with a hair dryer and start to lift it carefully to see if the paint will survive. No script is nice.
Old 07-05-2007, 08:46 PM
GeorgeM's Avatar
Agree with Scott. Looks exactly like that. You can tell by looking underneath if the lid was drilled or came stock with the tail.
A good position is about half-way. No idea what the stock position is, I just eyeballed mine and put it where I though looked best.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 07-05-2007, 09:36 PM
rnln's Avatar
I used hair dryer and fishing line.
Fat butt 911, 1987
Old 07-05-2007, 10:09 PM
Look here for factory sheet on script location--->
1987 carrera emblem location
- Wil
EDIT--- translation: for Turbo, the distance from the bottom of the lid is 10.5 cm....not the 17.5 cm used for Carrera.
2.54 cm / inch.....someone's going to ask !
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-06-2007, 03:59 AM
David in VA's Avatar
I have the same tail, here are some pics of where my script is. I do know that a previous owner added the tail so I can't vouch for accuracy vs. the factory location but I think it looks pretty good.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 07-06-2007, 04:51 AM
deshetlr's Avatar
Will, I have been searching for that thread for quite a while.
Scott
Old 07-06-2007, 07:38 AM
The best fix for this is to leave the script where it is and get rid of the tail. Ruins the lines of the beautiful body.
Like putting a backpack on a beautiful naked woman.
IMO.
Old 07-06-2007, 11:04 AM
It's about 7" from the bottom of the deckid to the Carrera script. Some people put the script lower, but to me it doesn't look right lower. I can post pics of the tail on the car if you want.
Old 07-06-2007, 11:22 AM
Well...the factory measurement of 17.5 cm from the bottom of the decklid equates to 6.88 inches...so 7" sounds about right.
- Wil
Wil Ferch
Old 07-06-2007, 11:46 AM
there are times when .1" means a lot, and this ain't one of them.
Old 07-06-2007, 11:58 AM
I agree with Tcar - pics please.
Old 07-06-2007, 03:54 PM
