sparkplug reading help.
I just changed my sparkplugs and they look like this:
The most interesting are number 3: and number 5, looks like it been burning oil?: The rest more or less looks like number 6: ![]() They have been in the car for about 6000-6500 miles. Any comments?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Bump.
BTW, the car ran a lot sweeter with new plugs!
My understanding is that with today's liquid that passes for gas you can no longer tell what is going on by looking at plug colors. I would say that number 5 looks like it has been burning some oil. Do a search on Marvel Mystery Oil as I believe some have had success with this oil additive to 're-seat' rings and such reducing blow-by and putting off the dreaded engine rebuild.
Not an expert, just regurgatating what I have heard.
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
Somatic Negative Optimist
Are these the right plugs for your engine?
They look like they are running a little too hot. I would do a compression/leakdown because there is some evidence of burning oil. Also, why is there so much gunk on the threads? Do you torque the plugs with about 19-20 ft-lbs?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
I was recommended the NGK BP7, so that is what I used. The gunk may be anti seize, that I used at the time, no excessive amount.
Not sure what they was torqued to. The new plugs are the same type of plug, had them on a shelf for a year, installed clean and torqued ~200 degrees, as shown on the back of the box. Could the anti seize cause overheating of the plugs, or what was the reason for not using it?
Anti-sieze can act as insulation between the plug and the head. The plug needs a good ground to produce a nice spark.
Not sure what it would do to the plug, but it may explain your increased performance.
Don't slather it on. Apply A.S. equivalent to this O on clean threads. That should do it. The gasket seat should provide more than enough of a contact surface for an electrical ground path. Sherwood |
I got new plugs now. I'm going to a track day on Sunday, so I'll be putting 4-500 miles on it this weekend.
I'll check my plugs again in 1000-1500 miles and see how they are doing. My engine are euro 2.7 with 112k miles on it, no rebuild, it might need a top end soon.
coolcavaracing.com
Good luck on Sunday Magnus. What track is it?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Thanks Pål!
Mantorp with PCS. Your car isn't ready for the road/track yet?
coolcavaracing.com
No, my car is still has a long way to go
safe:
I see a piece of insulator missing on #5. Check what Porsche recommends. NGK BP7 may be a little too hot for your 2.7. I have a feeling that NGK BP6 may be a better plug for you. Anti-seize is good, use very little and do not put any on the lower 2 threads.
