While the engine is out, what to do?
What are some things to consider doing while the engine is out of the car (911 SC) for a clutch? I suppose yet another attempt at soundproofing is in order even though the last ended up falling on top of the motor in about a week.
Change the ring gear and maybe even the starter.
Henri '87 Carrera coupe: Venetian blue |
Senior Member
oil thermostat o-ring.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
search by "while I'm in there" or something like that. There are several discussions including one I started back in 2003 or 2004. Some folks have shared spreadsheets of information. It's a pretty long list of things you'll want to consider.
'83 SC |
If I remember correctly, there is a whole chapter on this in Wayne's 101 projects book. Mine is currently on loan, so I can't help. But if you don't already have the book, now would be a good time to pick one up.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
'83 SC |
That's a helluva to-do list but it gets my mind off the premature clutch failure. Didn't expect to see the engine out for a long time to come. Thanks for the good info
twin turbos
63 356 So Called Outlaw 76 930 |
Trotskyite
or nitrous.
Valve adjust is so easy with the engine out. If you are even close to needing a valve adjustment, do it now.
How are the plugs? Change the oil pressure light switch at the front of the engine, right next to the thermostat. It cost $6.95, When it start leaking, it leaks bad. It was the reason for my last engine drop.
PorschePilot 74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration MID9 Member Beechcraft V-Tail Bonanza (Fly'n high and low) |
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Senior Member
Polish the intake ports and runners. Balance the crank and shuffle pin the case. I hope you can tell I'm kidding.
Remove the darned noise pad and sand/paint the fire wall. Intake runner boot replacement.
Make Bruins Great Again
Rear Main Seal
Front Trans Seal CHT sensor Oil temp sending unit Top dead sensor + Speed sensor Clean and paint engine tin Oil return tube O-Rings
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera Last edited by Por_sha911; 08-24-2007 at 04:30 PM.. |
I did the same thing to my SC about 6 months ago. I went over a few extra things while I had the opportunity.
A thorough cleaning Clutch - I went with a light weight alloy ($900 instead of $700 AUD) Plug wires Exhaust - removed heater shields, replaced gaskets, and painted Plugs Valve Adjust Fuel filter Engine/trans mounts Powder coating ($180 for tinware, fan, fan shroud, injector tubes, engine brace and other bits Gaskets - as many as I could get to Main seal (The one next to the clutch behind the fly wheel) New fly wheel bolts New injector rubbers New rubber hoses and injector seals and seats Fan belt Chain tensioner oil lines All up including the clutch I spent under $2K in OZ dollars. I had some help from friends to remove and replace the engine and I've had some great feedback from a recent concourse day. One regret - I wish I had changed the fly wheel as well. Some photos of the finished product Cheers Kent 81 SC Ford Falcon XR6 Turbo (245kw 500Nm) Ford Territory (192kw 400Nm) ![]() ![]() ![]()
Slumlord
On a budget (I always am) I would look for oil leaks and fix them (even if it means splitting the case) and replace and O-rings and cheap seals on top of the engine (oil thermo-stat, main rear, and any crsh washer on oil lines that might be leaking).
Other than that I would only remove and paint the engine tin, same valve covers (and polish them flat). Adjust the valves and drive it. And inspect the fuel lines. In some ways this could be the most important issue. A few oil leaks won't hurt anything. A fuel leak will likely destroy your car, and your fuel lines are probably 25+ years old now. |
19 years and 17k posts...
Beautiful!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
+1, mine is leaking like the Titanic. It is going to be a PITA to swap that one.
I'm trying to fix my autoheat and working on the flapper boxes is a huge pain. I would clean them up while the engine is out. If you happen to snap a stud it won't be as big a deal to drill and tap, and add a new stud.
For Sure::::: THE FUEL LINES!!!!!!!!!!!! Any aging rubber.....
Lots of info here to be had on just how far you want to go! BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Mono balls on banana arms. Easy with engine out!
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
