Super_Dave_D's Avatar
Originally Posted by tfiv View Post
I see new Ps and Cs in your future
OK so enlighten me as to how you can make that statement?
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 09-21-2007, 09:28 AM
dweymer's Avatar
the head ports look just like Johns(disfin) did. Looks like a used crack pipe, I imagine.
Donnie
Currently Porsche-less.....
Old 09-21-2007, 09:41 AM
Sorry for the pessimism Dave. Obviously I don't have the details, but with those leak down numbers and the amount of oil that's making it's way into the combustion chambers it's my guess. Maybe it's all valves and guides. Maybe you'll get lucky, I never do. I'll be curious to hear how the pistons and cylinders measure.
Old 09-21-2007, 09:48 AM
FenderGuy's Avatar
[QUOTE=charleskieffner;3473161]
powder coat engine tin/fan/etc. it goes on and on.............
cad plate fan housing strap
cad plate all nuts bolts washers (cheap)
QUOTE]
Not to hijack this link, but I thought a top end was around 5k? Patrick quoted me that price when my 3.0 eat a piston ring?
Chuck do you know of a shop that does this in Az? I am thinking of doing and engine drop to clean the engine up and fix leaks
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 09-21-2007, 10:01 AM
MBruns for President
JeremyD's Avatar
Originally Posted by rick-l View Post
What happened to the subscribe link that used to be at the bottom of each thread?
It's now under the "Thread Tools" at the top... took me awhile to find it too.
Too early for the P & C debate until they are measured. 400mile/qt is alot of oil - better to do this now than to wait until you drop a valve...
Old 09-21-2007, 10:04 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Can't always count on what the eye sees in the exhaust ports as far as buildup goes. If someone runs some Berryman B-12 or Techron in there, those big globs would be gone and you'd think everything was decent- except the port showing oily film/wet versus big glob of crud. Hence the reason oil consumption is a good gauge to go by.
My car had 78K on the clock and both the intakes and exhausts were goners, along with heavy wear on the rockers and shafts. Oil consumption was high and so was the valve clatter. No sign of oil staining in mine like oil changes may have been too infrequent or low quality oil usage.
Kevin L
'86 Carrera "Larry"
Old 09-21-2007, 11:30 AM
[QUOTE=KTL;3491253]Can't always count on what the eye sees in the exhaust ports as far as buildup goes. If someone runs some Berryman B-12 or Techron in there, those big globs would be gone and you'd think everything was decent- except the port showing oily film/wet versus big glob of crud. Hence the reason oil consumption is a good gauge to go by.
QUOTE]
At least two of them were wet and oily.
2015 Audi S3
Old 09-21-2007, 11:51 AM
looking for answers
disfin's Avatar
Dave,
Like donnie mentioned, your exhaust ports look like mine did. Here is a before and after picture. The head work was done by Bob at Anchor Atlantic in NJ.
Based on your smoke on decelleration, you will correct the majority of your oil consumption by doing the head work alone. Rings are a good idea too. Remember, sloppy valve guides will create oil consumption issues, but not the compression/leak down issues you are having.
My p&c's measured in spec and i hope yours will too.
Good luck, and keep the pictures coming!
John
87 Targa, Up for Sale!
77 Wife, stock
Old 09-22-2007, 01:53 PM
OldTee's Avatar
cams, cams, cams, cams. Get a 964 grind on your cams. Time for new valves. Expnsive I know, but at least do the exhaust. I hope he is going to pull the pistons and mic the lans. If OK reuse your cylinders and rings. Have the pistons bead blasted. Heads too. It is only money but you will be happier in the end.
Old Tee
all 911s sold
Old 09-22-2007, 05:50 PM
HarryD's Avatar
The subscribe button is now listed in the "Thread Tools" button at the top of the page.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-23-2007, 09:32 AM
So Dave,
how did the top end rebuild turn-out and what was the final cost?
Scott
___________________________
1985 Carrera Targa - Guards Red
2006 Acura TSX Navigation - Milano Red
Old 10-23-2007, 03:42 PM
DanielDudley's Avatar
Originally Posted by Super_Dave_D View Post
Extremely high oil consumption was the reason. The car actually ran pretty well even in its condition except to a real slight miss - a couple plugs were fouled. He had't got down to the rings/bores yet. I will let you know.
Do you think your previous mechanic was running different plugs on the wet cylinders ? It has been known to happen.
Old 10-23-2007, 04:26 PM
Originally Posted by wnsgc View Post
So Dave,
Thats the $1,000,000 question - All of the sheet metal came back from the powdercoater and it SHOULD be ready on Friday. Its been killing me and I cant wait to get her back. The wife even commented that she cant wait until I get my car back so I can get out of her hair! Hopefully Friday will be a good day!
2015 Audi S3
Old 10-23-2007, 05:15 PM
THECARREAPER's Avatar
nice thread. not to hijack, but what is wrong with castrol oil? i just changed my oil on a mew to me 89 911 and i used castrol 20/50.
thanks
Old 10-23-2007, 05:52 PM
charleskieffner's Avatar
super duper dave keeps us posted.
fender guy the two i know are patricks and jack at stuttgart. take your pick. or my buddy nels if hes not building vintage bug vans or off road porsche motors.
Old 10-23-2007, 07:27 PM
HarryD's Avatar
thanks
Read this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils-post3548759.html#post3548759.
I know it is long but well worth it.
Harry
2020 MB E350 4Matic
Old 10-23-2007, 08:11 PM
Originally Posted by HarryD View Post
Read this thread: http://forums.pelicanparts.com/showthread.php?p=3548759#post3548759.
thank you! will do!
Old 10-24-2007, 02:59 AM
well its been a long time - waaayyyy too long. She should be on the road tomorrow. This is what she looks like today. Sorry about the pic quality - all i had was my phone.
2015 Audi S3
Old 10-29-2007, 09:51 AM
bourgeois911's Avatar
Purty!
Old 10-29-2007, 11:18 AM
You got lucky on the Ps and Cs? I take it they were in spec.?
Old 10-29-2007, 11:27 AM
