LinkBack Thread Tools Rating: Thread Rating: 26 votes, 3.77 average.
Taking it apart is easy
Jerome74911S's Avatar
This thread is approaching 100 pages according to my computer. This is beyond mind-boggling, so I've decided to switch to extra virgin olive oil. Mainly I like the virgin part and, anyway, the engine will likely last as long on this as it would with some of the witch's brews people toss in there.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 09-11-2012, 09:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1881 (permalink)
Banned
But does that extra virgin prevent tappet wear?
And where in the heck does one find "virgin", let alone an extra one? Sounds like you'll need the unicorn tears additive.
Old 09-11-2012, 10:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1882 (permalink)
No worries. I bought some of that ZDDP additive, so this should take care of the flat tappets. Also, it's good on popcorn.
Jerome
Old 09-11-2012, 11:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1883 (permalink)
333pg333's Avatar
Originally Posted by j911brick View Post
maybe we did. Most people don't own a car long enough to wear out the motor; and most people don't participate in a oil analysis program so they have no idea if they are doing damage to the motor.
Still inclined to think we'd have masses of information to show that this actually happened.
Patrick
Youtube 333pg333
86 modified 951
Old 09-11-2012, 11:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1884 (permalink)
wasserkuhl's Avatar
On forums all over the world the debate continues.
Reminds me of the Religion vs Evolution debate.
Synthetic oils have their place for long drain interval modern cars ( not for my modern cars though..)
All I know is Give me a Dino oil anyday for an older Porsche, with short Drain and filter intervals........
Works for me and I don't have to woory about major engine failures. Haven't had one yet.
Old 09-12-2012, 12:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1885 (permalink)
bryvincent's Avatar
does anyone use Motul Classic 20W50? its a dino oil rated API SF/CC so i assume it has adequate ZDDP. while its still expensive for a dino oil, its about half the price of the Motul 300V.
Or is the Motul 6100 15W50 synthetic API SL/CF a better option?
All Products — Catalog Products — CLASSIC OIL 20W50 2L | Motul
All Products — Catalog Products — 6100 SYNERGIE 15W50 5L | Motul
Old 10-08-2012, 06:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1886 (permalink)
bryvincent's Avatar
oops.
Old 10-08-2012, 06:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1887 (permalink)
My 85 911 has had castrol 20/50 for almost it's entire life. (records) I switched to Valvoline VR1 on my last oil change. My car has 143,000 on it now and passed smog last 7 checks and runs great. Dang, I hope the motor is not ruined!!!Glory be to the VR-1, the Deep purple and the holy Brad Penn amen.
Old 10-08-2012, 09:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1888 (permalink)
Kind of Blue
MrBonus's Avatar
Is there an appreciable difference between Swepco 15W40 and 20W50 for a 72,000 mile '89 driven in the Mid Atlantic/North East area? I'm about to order some oil and I can't make a decision between them.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 10-22-2012, 04:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1889 (permalink)
wasserkuhl's Avatar
look in your owners manual and there is a little chart that will guide you to the weight to use for your climate.
I would be using 20W50 as I am in a warmer and not cold climate
Old 10-22-2012, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1890 (permalink)
Kind of Blue
MrBonus's Avatar
I have and either fit the temperature profile of my region. I was wondering if one had superior additives for our motors compared to the other or if it doesn't make a difference.
Old 10-22-2012, 05:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1891 (permalink)
HarryD's Avatar
I would only expect the only difference to be the weight. The additive pack should be the same. This appears to be confirmed by the product data you can access from this web page: SWEPCO 306 Supreme Formula Engine Oil | Southwestern Petroleum Corporation [Click on the Technical Data Tab at the bottom of the page and open up the .pdf file called "swepco_306_supreme_formula_engine_oil_sales_brochu re_j08346.pdf"].
As noted by others, you will need to decide what weight is appropriate for your climate and use. FWIW, I always use 20-50W in Portland Oregon.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-22-2012, 05:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1892 (permalink)
j911brick's Avatar
You shouldn't use additives in your oil.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 10-22-2012, 09:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1893 (permalink)
HarryD's Avatar
James, I think he was asking about the additives that at included in the oil not additional ones the end user might add.
Harry
2020 MB E350 4Matic
Old 10-22-2012, 10:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1894 (permalink)
The only differentiation I make between the two is the 15w40 is good for ambient air temps up to about 90F and the 20w50 should be used above 90F.
I wouldn't use the 20w50 for cold starts regularly under 32F.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 10-23-2012, 03:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1895 (permalink)
wasserkuhl's Avatar
What is the possible negative consequence of using 20w 50 below 32f? ie: damage?
Old 10-23-2012, 03:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1896 (permalink)
Yes, damage, as the oil gets too thick to flow properly.
Charles Navarro
Old 10-23-2012, 03:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1897 (permalink)
A fellow Pelacanite
NathanUK's Avatar
What's wrong with adding additives ourselves to our oil?
Have I missed something?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-28-2012, 09:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1898 (permalink)
AutoBahned
RWebb's Avatar
adding your own can upset the balanced package of additives that a group of experienced chemists and engineers designed for the oil
Old 10-28-2012, 10:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1899 (permalink)
A fellow Pelacanite
NathanUK's Avatar
I agree. What about adding ZDDPlus though?
http://www.zddplus.com/
Old 10-28-2012, 11:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1900 (permalink)
