Taking it apart is easy
This thread is approaching 100 pages according to my computer. This is beyond mind-boggling, so I've decided to switch to extra virgin olive oil. Mainly I like the virgin part and, anyway, the engine will likely last as long on this as it would with some of the witch's brews people toss in there.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Banned
And where in the heck does one find "virgin", let alone an extra one? Sounds like you'll need the unicorn tears additive. |
No worries. I bought some of that ZDDP additive, so this should take care of the flat tappets. Also, it's good on popcorn.
Still inclined to think we'd have masses of information to show that this actually happened.
Patrick Youtube 333pg333 86 modified 951 |
Reminds me of the Religion vs Evolution debate. Synthetic oils have their place for long drain interval modern cars ( not for my modern cars though..) All I know is Give me a Dino oil anyday for an older Porsche, with short Drain and filter intervals........ Works for me and I don't have to woory about major engine failures. Haven't had one yet.
does anyone use Motul Classic 20W50? its a dino oil rated API SF/CC so i assume it has adequate ZDDP. while its still expensive for a dino oil, its about half the price of the Motul 300V.
Or is the Motul 6100 15W50 synthetic API SL/CF a better option? All Products — Catalog Products — CLASSIC OIL 20W50 2L | Motul All Products — Catalog Products — 6100 SYNERGIE 15W50 5L | Motul |
oops.
My 85 911 has had castrol 20/50 for almost it's entire life. (records) I switched to Valvoline VR1 on my last oil change. My car has 143,000 on it now and passed smog last 7 checks and runs great. Dang, I hope the motor is not ruined!!!Glory be to the VR-1, the Deep purple and the holy Brad Penn amen.
Kind of Blue
Is there an appreciable difference between Swepco 15W40 and 20W50 for a 72,000 mile '89 driven in the Mid Atlantic/North East area? I'm about to order some oil and I can't make a decision between them.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
I would be using 20W50 as I am in a warmer and not cold climate
Kind of Blue
I have and either fit the temperature profile of my region. I was wondering if one had superior additives for our motors compared to the other or if it doesn't make a difference.
As noted by others, you will need to decide what weight is appropriate for your climate and use. FWIW, I always use 20-50W in Portland Oregon.
You shouldn't use additives in your oil.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
James, I think he was asking about the additives that at included in the oil not additional ones the end user might add.
I wouldn't use the 20w50 for cold starts regularly under 32F.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
What is the possible negative consequence of using 20w 50 below 32f? ie: damage?
Yes, damage, as the oil gets too thick to flow properly.
A fellow Pelacanite
What's wrong with adding additives ourselves to our oil?
Have I missed something?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
AutoBahned
adding your own can upset the balanced package of additives that a group of experienced chemists and engineers designed for the oil
A fellow Pelacanite
I agree. What about adding ZDDPlus though?
http://www.zddplus.com/
