Why does not fit - 915 gearbox to 3.2 engine?
Hi,
I need help. My mechanics say that my 915 gearbox from 1975 does not fit to recently bought 3.2 US engine from 1984. Is it possible? If so are there any technical possibilities to match them?
What type of gearbox should I have for that engine?
Marcin
1976 3.0 Carrera sold
1975 2.7 backdated to 73' RS
1971 2.2 T Targa
Old 10-09-2007, 12:23 AM
group911@aol.co's Avatar
It just needs the notch cut out for the flywheel sensor. You can probably do a search her to find out where and how.
Thanks,
Bob
group911@aol.com
Old 10-09-2007, 03:58 AM
Administrator
Jack Olsen's Avatar
You also need to address the mechanical/electronic speedo issue, but it's pretty minor.
Old 10-09-2007, 10:14 AM
MBEngineering's Avatar
HI you will need the cutouts as the photo's below
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 10-09-2007, 10:44 AM
Tom '74 911's Avatar
I have a question regarding the required cutout - how barbaric can one be in creating this? Do you need to send the trans. to a capable machine shop (assuming this is the best), could you just hack away yourself? Is it OK to machine/cut an older trans. case in the first place?
Thanks a lot,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 10-09-2007, 10:56 AM
GFCC
Jeff's Avatar
You can just cut it with a saw.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 10-09-2007, 12:18 PM
Driveline support
GBOX's Avatar
Or send it to someone who will place it on the milling machine and make a clean cut of it.
Ryan W. Zielinski
GBOX LLC.
Phone: 303-440-8899
mail@gboxweb.com
www.GBOXWEB.com
Old 10-11-2007, 03:46 PM
I used an air powered grinder to make the cut-outs in my 72 915 transmission. The mag cased transmissions are easier to grind than the aluminum ones. It has worked just fine. I have the cardboard template somewhere in the shop, but I would be hard pressed to find it right now.
Tom Oxner
Old 10-11-2007, 04:04 PM
