lookin's Avatar
Oh _ _ _ _ my car doesn't go into gear and the clutch is on the floor
Pelican heads-
Came back from a nice Sunday drive with the wife. Turned off the car to unload some stuff from my truck. Came back fifteen minutes later, started up the car and tried to put it into gear. No go and the clutch pedal is almost at the floor.
I haven't even looked at it yet. What do you guys think happened so quickly and without any warning or noise except for grinding of the gears? Center of disk collapse?
Thanks for your comments,
Dale
75 911s, sold
02 boxster
06 dodge diesel
It's all about the dash
Old 10-14-2007, 06:36 PM
Is this for the 75 ( as noted in your signature block) or the boxster? If it is the 75 you need to look at the clutch cable, the adjuster nut and the omega spring. Look for them on the drivers side under the car at the tranny. If you can jack up and shoot a picture, that might be very helpful.
Tony G
2000 Boxster S
Old 10-14-2007, 06:48 PM
lookin's Avatar
Tony-
It's for the 75.
I just crawled under the side with a flashlight. The clutch cable is still attached at the tranny and the arm assembly the clutch cable attaches to is stiff when I try to push on it with my hand, so I don't think it's broken.
I have to charge up the camera, so I'll take a pic later tonight or tomorrow and post. thanks
75 911s, sold
02 boxster
06 dodge diesel
Old 10-14-2007, 07:19 PM
lookin's Avatar
tony-
just had the wife get in the car and push in the clutch while I looked at the arm assy at the trans. the assembly only moves a 1/2" at most.
75 911s, sold
02 boxster
06 dodge diesel
Old 10-14-2007, 07:25 PM
Slippery Slopenose Victim
SXSMAN's Avatar
Look closely at figure 16 . I've seen a number of these break and cause problems like you're having .
http://www.pelicanparts.com/techarticles/911_clutch_cable/911_clutch_cable.htm
Let us know what you find .
SxS
sxsman@hotmail.com Have guns , will travel
Mr. Potato-head , 1974 911 Slant/turbo look 2.7
1963 Cooper S ex-C sedan , 1974 Vespa Rally , 1974 TVR 2500M (sold) ( Musta had massive head trauma in 74 , ya think ? )
Old 10-14-2007, 07:38 PM
3.2Carrera's Avatar
Hey dale,
You might want to take a look at the pedal-bushings. My friend has a 1979 911 sc and he had the same problem you are describing. He replaced the pedal-bushing and everything was fine. Good luck!!
Old 10-14-2007, 09:11 PM
lookin's Avatar
Everyone-
I'll get it on the stands on Wednesday afternoon, check it all out and post some pics.
this forum is the best.
Dale
75 911s, sold
02 boxster
06 dodge diesel
Old 10-14-2007, 09:18 PM
let us also know what happens when you pull the clutch pedal back up manually. Does anything underneath change? It is possible you have a broken clutch cable.
Tony G
2000 Boxster S
Old 10-15-2007, 05:35 AM
I'm with Bill
Jims5543's Avatar
Does the shifter linkage feel normal?
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 10-15-2007, 06:38 AM
SCWDP911's Avatar
Take a close look at the cable. Mine recently did the same thing as yours (symptoms), and luckily, it was just a cable that was starting to separate. Mine was about halfway separated right where it attaches at the tranny end, but yours could also be at the other end. Like someone else mentioned, it could also be your pedal assy (there is a rolled pin that locks the pedal to the assy). Good luck with it. The cable job should take a couple of horus. I was also lucky and had some good help from a fellow Pelican that lives an hour away. The hardest part was when I went to reattach the cable to the pedal assy end. That end proved to be a pain due to tight quarters and a "slightly" wider girth on my part! I can post some pics later if it would help.
Shane
- 1984 928S
Old 10-15-2007, 12:17 PM
SCWDP911's Avatar
Take a close look at the cable. Mine recently did the same thing as yours (symptoms), and luckily, it was just a cable that was starting to separate. Mine was about halfway separated right where it attaches at the tranny end, but yours could also be at the other end. Like someone else mentioned, it could also be your pedal assy (there is a rolled pin that locks the pedal to the assy). Good luck with it. The cable job should take a couple of hours. I was also lucky and had some good help from a fellow Pelican that lives an hour away. The hardest part was when I went to reattach the cable to the pedal assy end. That end proved to be a pain due to tight quarters and a "slightly" wider girth on my part! I can post some pics later if it would help.
Shane
- 1984 928S
lookin's Avatar
Hey Everyone-
Sorry for taking a while to post. I've been too busy with work, which is a good thing.
Earlier in the week I started taking things apart and found my shift coupler bushing had completely disintegrated on one side. Perfect excuse to go to wevo and pick up a new coupler and a classic style shifter. (hayden & tyson are real nice and they took the time to answer all my newbie q's)
Installed these parts yesterday and still had the clutch problem, which I figured I would, so I took out the cable earlier today and it looked so good I reinstalled it.
Adjusted everything and took the car for a ride with the neighbor and whamo the pedal goes all the way to the floor.
Limped the car home, took off the wood floor board panel, pushed on the clutch pedal and realized the clutch cable wasn't moving. And the problem is: the clutch pedal has a clevis pin sp? which has sheared off or wasn't installed correctly when the assembly was rebuilt by the previous owner. Cool, I've found the problem.
Do you guys think I can replace this clevis pin without removing the assy?
Thanks for your comments.
Dale
75 911s, sold
02 boxster
06 dodge diesel
Old 11-08-2007, 04:45 PM
Some of the after market pedal bushing replacement kits supply a replacement pin that is way too soft and eventually fails either by bending or breaking. If it bends the action of the pedal slowly deteriorates over time and you might not notice it in daily driving. I had this happen with a 930 at Road Atlanta.
Get the factory replacement pin. It can be repaired in the car (we did it at the track) but it's neither fun nor easy due to the working space. Removing the seat will help.
Good luck.
Old 11-09-2007, 08:29 AM
Thrasher's Avatar
there's a comparison picture somewhere in the archives of the ends of the roll pin (not clevis) that you need. The best way to describe it is that the end doesn't just make one circle, but is more spiral, like a cinnamon roll ;-)
The simple c-shaped/circle ones fail all the time.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 11-09-2007, 09:11 AM
I'd forgotten what it looked like. Same for the roll pins on Bilstein inserts.
Old 11-09-2007, 01:18 PM
lookin's Avatar
thanks for the replys. I ended up going to high performance house and they set me up with a good roll pin.
It was a tight fit, but I was able to get it installed.
thanks for all the replies.
dale
75 911s, sold
02 boxster
06 dodge diesel
Old 11-12-2007, 11:08 PM
