Porsche 911 SC, SAAB SPG
What is needed to install G50 w/3.2 into 1982 SC
The engine should slip in without issue, but I'm not sure about the new style tranny.
Can it be done by just swapping/adding parts or is there a bigger difference like mouting points and axle location changes?
At this point, this is just research and nothing has actually been bought or done yet.
Thanks for any input.
Old 10-15-2007, 06:53 AM
Bill Verburg's Avatar
2 ways to do that
1) shorten a G50
2) cut the t-bar housing and then replace w/ '87-89 version or replace rear suspension w/ coil overs.
neither is easy to do or cheap and IMO not at all worth it. Spend the time, $ and energy on a 915.
Bill Verburg
Old 10-15-2007, 06:59 AM
Like Bill said it won,t be easy ! and there is the costs offcourse ... i love my G50 don,t get me wrong but Wevo has some nice stuff to make a 915 into a great box.
Cheers,
87 Carrera Backdate
Old 10-15-2007, 07:05 AM
Thanks for the very quick responses.
Will take the advice and stick with the 915.
As a follow up question, will a later year (1987-1988) 3.2 bolt up to a 915?
Old 10-15-2007, 07:10 AM
yes, preMY84 trans will need to cut a notch for the flywheel sensors
Bill Verburg
Old 10-15-2007, 07:41 AM
DanielDudley's Avatar
Send your tranny out to Gary Fairbanks. If that doesn't do it, I'd be real surprized.
Old 10-15-2007, 04:47 PM
KTL KTL is offline
Schleprock
KTL's Avatar
What year is the 915? If it's 84-86 then there's no need to notch. But you'll still have to install shorter engine case studs on the 87-88 engine to mate the 915 trans.
Here's a couple of nice topics to make you aware of what's needed to throw a G50 into a non-G50 car..............
http://forums.pelicanparts.com/porsche-911-technical-forum/362061-project-g50-post3436141.html#post3436141
G50 Conversion Project Begins
Kevin L
'86 Carrera "Larry"
Old 10-16-2007, 04:07 PM
