LinkBack | Thread Tools |
Rating:
Somatic Negative Optimist
An overhead beam with a short steel choker, a 3/4-ton Come-along and a home-made spreader bar did the trick for me.
If you can access a beam or truss on the ceiling you can make a set-up for future use. I use small shackles on the engine with 2 steel chokers going up to the hook and the spreader-bar (made from a 2x4) keeps the chokers from rubbing against the engine/intakes. That gives full control over the whole process. After lifting it off the stand, I set the engine on it's HE's onto 3/4" plywood on the floor, attach the transmission, then lift the whole unit again onto a narrow, low 4-wheel Dolly and roll it under the rear of the 911. Then I raise each side carefully with small floor jacks and short pieces of 2x4 enough to get the Dolly out and the big floor jack onto the "sweet spot" in front of the sump plate to start the final jacking. It's important to secure the whole unit sideways with dunnage to prevent it from tilting and falling off as you go up. It's a one-man operation; very safe. ![]() A made a lifting-plate from 3/4" plywood to get perfect balance on the jack.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Southern Class & Sass
Cleaned up the transmission and engine tin today. The trans may not be spotless, but it's far cleaner than the black blob it started out as. Once I got it to this point I called it quits for the day. It's 54° and drizzling out. Funny thing is, Friday it was 80°.
Dixie Bradenton, FL 2013 Camaro ZL1 |
We might be separated by about 2,500 miles but we have similar issues [strangly similar?]. The leaky one on the left belonging to the bride and the one on the right needing a top end. I was going thru 1 qt per 200 miles. Just got it back yesterday from having the top end done by Patrick Motorsports in Phoenix. They did an awesome job, plus a 'few' other things while they were in there. I'd have loved to try to tackle something like this myself, but I know my limitations which end somewhere around oil changes and brake pad replacement.
Just had to post this pic when I saw your intial set of posts with your garage. Garage ![]() 'New" engine
This would be the time to check/replace the seals in the transmission.
Selector shaft seal, Guide tube seal, Axle flange seals are cheap and relatively easy to replace.
Finally hit the first real issue with the clutch project. Stripped screws. I suspect its gift from Stuttgart.
Any advice on how best to remove these screws?
Rick 88 Cab |
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Slumlord
And replace them with socket head cap screws.
Another help is to use "valve grinding compound" on the end of your screw driver tip. You won't believe the added grip it will give to the screw driver tip. It's magic...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
19 years and 17k posts...
Great thread, lots of excellent info here. Rob, thanks for documenting the whole thing!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
CrossT,
Quite a coincidence, no? Also, I like the silver fan and black housing. Think I'll try that.
Enlisted the help of several co-workers and got the engine off the stand today. Hooray! Here’s how things look after 30 minutes of effort. Intake installed, and rear tin mocked-up into place.
Gotta love the understated black & "silver" combo, in my case-Titanium Ceramic coating:
The impact driver did the trick. The guide tube screws are out. The trans now has new seals. And the engine is together.
Unfortunately, the two are still separated. Why? Because I broke the throwout bearing. One too many pumps on the press while installing, and it's now a $115.00 piece of junk. Now I'm waiting on the replacement to arrive.
When I did my clutch a couple of years ago, I didn't need my press. That seems to be asking for trouble, try the new one without it.
Yesterday I tended to a few odds-and ends.
I replaced the horrid double-strut setup/kludge for the engine cover. What I had was two struts on the RH hinge, held in place by clevis pins. It was a PITA to remove. The clevis pins were bent and grooved. ![]() I replaced it with the OEM setup. I aquired a RH turbo hinge, new struts, factory pins, clips, and spacers. A bit of paint and this is what I have now. ![]() Next I removed the rear bumper. That should make getting the engine in a bit easier. I won't have to raise the rear of the car so far. ![]() Time to sign off. Today's goal is getting the engine and trans joined, and into the car.
Back again. Today was pretty productive. I spent the first half of the day getting the engine and trans assembled. It took longer than I expected.
![]() By 3:30 the engine is in, and everything up top is hooked back up. Tomorrow I need to finish hooking up everything underneath.
Once again, AWESOME thread!
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Schleprock
![]() And yes, you don't need a press. I use my body weight on top the contact side of the clutch housing. Under the release bearing I put a short 2x4 laid across it. Instant 170 pound human press with just enough weight to flex the springs and allow me to install the release bearing shims, thrust washer and retaining clip. ![]() By the way, congrats on getting it all back together.
Kevin L '86 Carrera "Larry" |
Good luck on the first startup
