engine idle while oil cap removed question
Just finished changing the oil and went through the fill up drive and check procedure. I opened up the oil tank there was only a subtle change in rpm. I was under the impression I would hear a big change. Let me guess a vacuum leak some place else?
David I don't suffer from insanity, I enjoy it. '79SC Targa '2021 CRV |
My RPMs drop pretty significantly when I remove the cap.
I have never looked at tach to see how much it drops but it is a very noticeable change. It may be best for you to see someone else's so that you have something for comparison.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Pool Janitor
I'm curious too, I checked mine after the last thread on this topic. My RPM barely changes, only a keen ear would tell. Is it suppose to change?
-Ryan
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" < '88 Porsche Carrera Cabriolet Sold > |
Yes, idle rpm will change. The oil tank vents into the intake manifold. when the cap is removed it allows more unmetered air to enter the engine. There is a restrictor that reduces the amount of air other wise it would just die.
So as long as there is a change its ok even if its just slight?
Just jumping in ......on both our 911's we have a significant drop in rpm (or at least sounds like it) when the oil filler cap is removed.
What year 911s? I think that makes a big difference, doesn't it?
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Both of our's are 1985 - one ROW the other US spec.
so does this mean that my engine idle is compensated for a vacuum leak else where and it makes not diff if the oil cap is off?
