jthwan22
Guest
Posts: n/a
Post Odometer dead but speedometer works
My odometer is not working but the speedometer still works. Does that mean the speedometer sensor is ok and I need a new gauge? I pull the spedo out of the dash last night. Everything looks plug in with no loose wires. Any ideas?
1984 911 Cabriolet
Old 04-24-2001, 02:41 PM
Jim T
Guest
Posts: n/a
Post
The odometer gear is "slipping" on the axle that it is press fit onto, and that drives it. This is located in the gear cluster inside the speedometer. You of course need to open up the speedo to get to it.
I think there is a tech article on how to fix it somewhere on this site. Alternatively, any of the many speedo shops can fix it for you, its an easy job for them.
[This message has been edited by Jim T (edited 04-24-2001).]
Old 04-24-2001, 02:46 PM
fred hannah
Guest
Posts: n/a
Post
i have the same prob., but my gear was stripped, not just lose like the tech article describes. i havent got it fixed yet. its only a little brass gear about half as long as a tooth pick. i cant imagine what that little sucker will cost. i called vdo and they said they could fix it, but that they would not sell me the gear so i could fix it my self, go figure.
Old 04-24-2001, 04:21 PM
Dug89
Guest
Posts: n/a
Post
Cha-ching. Never try to reset the trip odometer whilst moving. It will break the gear in the odometer.
Had a friend do this and he had to send the speedo off for repair. When getting it repaired have the shop correct the miles up to cover the miles driven while it was broken.
It is important that the work be done by a certified shop so that the repairs are documented. No sense in making your Porsche less valuable because the odo has been tampered with illegally.
Doug 84 911 ROW
Old 04-24-2001, 04:50 PM
Chris Lovell's Avatar
Odometer first, now speedo failed
My odometer failed a few months ago, and yesterday, the speedometer failed as well. I was thinking the speed/odo unit needs a rebuild but it just occurred to me that I was in the rear seat floor "hatch" yesterday working on the shift linkage. Do you think I disconnected something in there? '88 Cab
CL
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 08-03-2010, 04:39 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1984 911 Cabriolet
Lots and lots of posts on this subject.
Search odometer gear..........
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-03-2010, 04:54 PM
Hodgey's Avatar
sending mine to North Hollywood Speedo on recommendations from this board and from my ace local Porsche guys at Eurasian Auto in Birmingham........
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 08-03-2010, 04:58 PM
dshepp806's Avatar
Hands off,...to NHS for repair, I'd say. (as well as a requested speed recalibration)
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-03-2010, 05:37 PM
E Sully's Avatar
CL,
The odometer problem is most likely the common broken gear. The speedometer stopping could be one of the connectors for the sending units wires being loose. They are under the plate by the shift linkage.
Ed
1973.5 T
Old 08-04-2010, 07:36 AM
What is with all the guests? Edit: nevermind that is from 9 years ago
Odometer Gear replacement for Electronic Speedometers (long)
Rick
88 Cab
Old 08-04-2010, 10:31 AM
E Sully and all, Bingo! Disconnected wire under the shift linkage plate. I loosened this sending wire when I was adjusting my shift linkage. Speedometer works like a champ now. The odometer will need to be fixed by sending to a shop.
CL
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 08-05-2010, 07:42 AM
Detached Member
Hugh R's Avatar
I've heard that you can fix it yourself. I dropped mine off at North Hollywood Speedometer, they fixed, repainted the dial and calibrated it.
Hugh
Old 08-05-2010, 07:45 AM
