charleskieffner's Avatar
2820# car
230-me=
2590
showroom stock is limited to options for your year.
technically RUF bumpers were an option.
i might add the above weight was with (4) hellas and light pod on OEM hood weighed on PCA ZONE 8 scales at california mtr speedway.
you think yer skimming weight but as mentioned above it takes alot of little things to add up.
for resale IF i ever sell car and PCA rules our mantra has been "as it came from the showroom"
my best advice.................
buy a race car already prepped stripped suspended motored the WAY YOU WANT and not try and build one from a stock car. leave stock car alone and go putt putt and buy REAL racecar for the track. theres plenty out there to choose from every month in pano magazine.
you really limit yourself to buyers when a/c and heat are gone no matter where you live. add headers loud pipes strip everything out and the ONLY person that will want to ride with you is another certified GOOFY PORSCHE FREAKAZOID! like me!
Old 03-04-2008, 07:06 AM
Electric seats? V. heavy. Go to even stock manual sport seats to save a lot.
Dynamat is also heavy. Engine sound pad is nothing.
Bumpers and shocks are v. heavy.
Those big wheels and tires also weigh a lot more than those skinny tires on the long hoods.
Helium is a joke, BTW.
Old 03-04-2008, 07:24 AM
Air Medal or two
afterburn 549's Avatar
Hmm, stock bumpers are way over 60 lbs. Spare tire and jack ? over 40. All glass ?=HVY. Rocker panels and rubber unbelievable HVY. Pwr anything- widows, seats , mirrors=HVY
You need lt. wt. starter, some lexon , F.G.bumpers, C.F. hood, for results
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 03-04-2008, 10:16 AM
the sound mats on the inside rear package tray and the inside rear seat buckets are heavy....did you all remove these items too?
Old 03-04-2008, 10:53 AM
AutoBahned
RWebb's Avatar
Sherwood - do have actual wts. on the door beams? They look like sheet metal to me, thus much lighter than the shells themselves...
Concentrate any wt. saving work on the rear of the car.
Also, I would not trust the scales - from what you say they can weigh heavy trucks. If so, then they will not be that accurate for a car. The Or. scales along the hwy are checked to within 20 lbs. BUT they have never told me at what wt. they check them. Scales will still be somewhat useful for comparisons however.
To be more accurate (likely), find a buddy with a set of corner balancing scales. To be honest, the only thing you can really trust is a set of NBS traceable scales, that have had the calibration checked recently.
The data I compiled and those of Jim Calzia are accurate, but both are aimed at the early cars. This may help tho:
http://www.penaltykicker.com/911/data/
Old 03-04-2008, 11:07 AM
Send a message via AIM to PSportoVeloce
lightweight battery and one recaro race bucket now. 2553lbs as of today, without jack, tools, and spare, with 3/4 tank of gas.
Website: The Motoring Enthusiast
Work: Fantasy Junction
Current P-cars: 1987 Carrera "'74 Carrera Look"-Bali Blue || 1989 Speedster-Guards Red || 1989 Carrera 4-Velvet Red || Grande project || and a bunch of other cars...
Old 11-03-2008, 03:27 PM
Formerly known as Syzygy
Canada Kev's Avatar
elec. motors & G-50 are heavy
lots of undercoating & sound proofing also
are the scales accurate?
I thought that the G50 wasn't that much heavier than the 915. Does anyone actually KNOW, as in having weighed both, to come up with a definitive answer?
Electric motors like the ones in the power seats are heavy. The electric windows are about the same weight as the manual AFAIK. The winding mechanism makes up for the weight of the motor. All of the rest of the stuff in there is the same regardless of power or armstrong lifting. I guess the 15 feet of wire might account for something... Power locks, maybe a bit o'weight.
If a scale that is designed to weigh loaded transport trucks (up to 150000 lbs) was used to weigh the car, it might be a few pounds off. The sensitivity at either end of its capability might not be so accurate. Your car might actually weigh MORE than what you think. Wouldn't that be a kick in the pants.
-kevin
Kevin
Old 11-03-2008, 04:01 PM
AutoBahned
RWebb's Avatar
that scale is likely off by at least 20 lbs. - as based on Or DOT truck scale calibrations
g50's are in fact heavier than the 915 -- a Mg cased 915 is less wt. than the last Al cased 915 -- the clutch is a substantial part of the g50 porkiness
there is a thread with some info on it - you'll have to search for it
Old 11-03-2008, 04:40 PM
-kevin
the difference of the G50 is not that large, something like 40 pounds, if i recall, but a sizable chunk of it is indeed the clutch. there is a thread where the weights are compared somewhere on here.
not much of a difference with electric/manual windows either.
the scale today was an electronic racing scale used for corner weighting.
Old 11-03-2008, 04:55 PM
Air Medal or two
NOT that large ??? I would pay a good chunk of $$$$$$$ ( and have ) to get rid if 40 lbs !!! Thats like amost 1/2 of a 100 !!
Old 11-03-2008, 07:44 PM
Nickatnyt's Avatar
Take a bag of trash to the dump and ask the person at the booth how much your car weighs when you exit. That is how I found out my Avalanche weighs 6,900 pounds....YOW!
1982 SC...Guards Red + Linen
Old 11-03-2008, 08:01 PM
Air Medal or two
Like already stated "those scales can be off (and more ) 20 lbs real EZ
Old 11-03-2008, 08:12 PM
My G50 weighed 20lbs more than the 915 I removed
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-03-2008, 08:22 PM
Mitch Leland's Avatar
There's another thread going on weights... I reported that my "84" Turbo Look was just weighed by electronic scales, 2799 lbs.
Includes:
3/4 full fuel, A/C, Sun Roof, LSD, 16" BBS Wheels, Optima battery, Tool kit and jack, Spare tire, Full carpeting, Less floor mats.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 11-03-2008, 08:25 PM
User
ikarcuaso's Avatar
Originally Posted by PSportoVeloce View Post
<snipped>
TIA,
Derek
Originally Posted by MOMO3.2 View Post
Wow, TIA your interior is AWSOME. ...
Who's TIA?
82 Targa
Old 11-03-2008, 08:58 PM
budge96's Avatar
Sporto veloce
did you remove evaporator and expansion valve in smuggler box? associated
hoses?
Rocker panel mouldings?
GT2
RS 3.2
RSCS 3.8
R 2.5 Twin Plug
Old 11-03-2008, 09:54 PM
Originally Posted by ikarcuaso View Post
Who's TIA?
haha it means "thanks in advance"
Originally Posted by budge96 View Post
Sporto veloce
hoses?
Nope, all that stuff is still in there. I just haven't had the chance to get rid of it yet.
The rocker moldings are still on the car also. Having a G50, the torsion bar covers are not round and kinda goofy looking, so when the moldings are off it looks a little too unfinished for my taste. I'm planning to take them off eventually when I get glass IROC bumpers, but right now, it has the 74 Carrera look, which I would like to preserve until I decide to "go to town" with it.
Old 11-03-2008, 11:09 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The above stuff mentioned by afterburn is exactly what I was going to comment on.
If you replace the hood and front/rear bumpers with fiberglass, you're going to lose according to my scale measurements:
Hood = -21 lbs
Complete front bumper = -33 lbs
Complete rear bumper = -37 lbs
Factory sport seats weigh 49 lbs EACH. That's what my RS America cloth 4way power seats weigh. Install a light track seat with alloy side mounts that weighs ~25 lbs like my Cobra Imola S
Lose the windshield washer bottle for up to 15 lbs depending on how full?
Lose the rear charcoal cannister for 5-1/2 lbs
Lose the side rocker panel trim for 12 lbs but I think the G50 cars look like crap without them
Install a custom muffler and you'll lose ~ 10 lbs (factory style banana mufflers are robustly built and heavy)
My car currently weighs 2650 with me in it fully equipped to go on the track (helmet, harness bar, harnesses, no jack, compressor) and a little more than 1/2 tank of gas. It's almost exactly equipped like the original poster's car, with few less, few more things that are not all that heavy.
I can still lose weight by eliminating factory door panels and speakers (rear speakers and radio already gone), sunroof, lighter exhaust system (I have custom muffler, factory exhaust manifolds and a Fabspeed premuffler), lexan windows and fiberglass fenders. I think my car is almost at the point where you really have to work to lose weight. Losing the sunroof, installing lexan windows and installing a real roll bar involves some commitment that kills some of the streetability of the car. But hey, my car is barely streetable anymore with 23/31 t-bars, R compound tires, squeaky brake upgrade, little sound deadening.......... I figure with some more changes the best I can do is a car that's around 2450 with 1/2 tank of gas and fully equipped for safe track driving.
Kevin L
'86 Carrera "Larry"
Old 11-04-2008, 11:34 AM
Administrator
Jack Olsen's Avatar
The simplest way to cut weight is to move from one 'certified' scale to another until you find one that gives you a great number. In my experience, there's a lot of variation in scales.
There's probably a little bit of exaggeration in some guy's online boasts, especially with how much gas they say was in the car. But who knows?
My car has all fiberglass except the roof, race seats, much of the interior deleted, lexan in the back and quarter windows, aluminum trailing arms and front crossmember, lightweight exhuast and a handful of other little weight saving tricks -- and it's still heavier than stock.
Old 11-04-2008, 12:54 PM
