Closed Thread
Throw it on the ground!
Well, I'm happy to report that the T1000 flush gun worked like a champ. I flushed 1/2 gal of mineral spirits in each direction then did a final flush with the Clean and Flush product from Autozone that has a little ester oil in it.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 03-23-2008, 08:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #81 (permalink)
deshetlr's Avatar
So Mark, is the flush strictly gravity fed? I'm a little confused as to how the process works.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 03-23-2008, 08:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #82 (permalink)
No, pressurized air (shop compressor) at 100 PSI. Scroll back and you'll see the air fittings and control valve on pg 4.
Mark
1987 911 Coupe
Old 03-23-2008, 08:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #83 (permalink)
deshetlr's Avatar
OK I see it. So you pour in the flush, close the valve and open the pressure? It looks like you have a bottom valve as well. Do you pressurize and then open the lower valve?
Scott
Old 03-23-2008, 08:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #84 (permalink)
The lower valve is just for convenience to keep the flush from running out when changing the connection line to the condenser.
Mark
1987 911 Coupe
Old 03-23-2008, 08:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #85 (permalink)
I like the T1000.... in the picture you are flushing the whole system minus the pump and rear condensor... right? Will the T1000 push the flush liquid past the exp. valve in both directions? I guess it does.. but just asking.
Old 03-23-2008, 09:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #86 (permalink)
Nope, rear condenser only - everything else is being replaced.
Mark
1987 911 Coupe
Old 03-23-2008, 09:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #87 (permalink)
"flush liquid past the exp. valve in both directions"
Do not flush an expansion valve.
For general information, the following A/C components should not be flushed: expansion valves, receiver driers (including Procoolers), nor compressors. Also modern parallel flow condensers/evaporators do not flush well due to the flushing fluid taking the path of least resistance among the many parallel paths thereby not cleaning out the other paths. This is particularly the case if one of paths is clogged or blocked. If one is going to flush an evaporator remove the expansion valve before doing so.
Old 03-23-2008, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #88 (permalink)
rbuswell's Avatar
Porsche Crest Bunch of sourcing and design questions
This is an exceptionally well done thread. Some top notch advice. My research points toward Griff being one of the top A/C guys around so to have his input is a big plus. I was curious about a few things however:
  • I hope this doesn't put you on the spot, Mark, (and Griff too, I suppose) but why didn't you buy the entire "Mr. Ice" Project components from www.griffiths.com instead of mixing and matching from different vendors? Did the component adjustments make a big difference in cost?
  • Griff, do you offer a kit type discount if we buy it all from you?
  • Griff, it looks like the protector plate for the fender mounted condensors are not the same as shown on your website. Did you find that by changing the shape for rock protection meant more air flow and better cooling?
  • Is it universally true that the A/C shops are going to do a marginal to poor job and that it makes sense to do the evacuation and charging ourselves?
Thanks again guys for a fabulous thread. You have no idea how many of us are struggling with the same problem!
1982 911SC
1987 924S
Old 03-23-2008, 10:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #89 (permalink)
kuehl's Avatar
rbuswell,
Good questions. I can't answer for Mark however we worked with him so he could have the system he wanted.
In answer to Griffiths questions:
i) do you offer a kit type discount if we buy it all from you?
Yes. The procedure for designing a system for your 911 or 930 starts off with gathering information about your car and climate through the Mr. Ice Project Question form http://www.griffiths.com/porsche/ac/ice/mricequoteform.html
Based on the current configuration of ac system, car, heat load characteristics, the condition of your present system. From there we draft up a proposal which includes our recommendations and "options" which you can add or delete to your customized system; based on your budget and objectives. All proposals include a base package of components (barrier hose sets matched to your car, drier, R134a conversion oil, charge port adapters, pressure switches, mechanical and electrical hardware, installation guidelines, etc.). The base package is pre-discounted ; we have already grouped together the items have reduced the prices in comparison to buying the items individually. With the "options" we have also offer discounted prices provided you purchase them at the same time; logically it makes sense to buy and install your ac components at one time and do the job right the first time.
ii) Griff, it looks like the protector plate for the fender mounted condensers are not the same as shown on your website.
The "Stone Guard" shown on the website may be one of our first designs, subsequently we tested other designs and found we could achieve the same protection however allowing for more air flow; stone guards are custom made by you when you install system since there are a various fender shapes out there (narrow body, carerra, turbo, custom, etc); we provide you all the materials with our systems and installation guidelines (plenty of pictures and text) as well.
iii) Is it universally true that the A/C shops are going to do a marginal to poor job and that it makes sense to do the evacuation and charging ourselves?
No. It is not true that shops do marginal work, at least not the shops we sell through or recommend. AC work is like any other work; there are procedures to follow, system theory and necessary tools. You can find shops that do marginal work on anything (tire balance, bodywork, valve jobs). I've seen some of the best shops (in terms of time in the business and reputation) fail at doing the work properly as well as handling the customer properly.
There is a universal truth that the stock system does not perform well therefore whether it is a shop, OE dealership or DIY working on a stock system the results are typically the same; poor.
The learning curve for the average DIY with the AC system is long. Although some DIY's may have success the first time out of the gate, the numbers are few and those who have had success have yet to hit a wall hard enough to know better. If you are a DIY and you are considering do the evacuation, charge and test procedures you logically have to add up the costs for equipment: evacuation pump, accurate gauge set, electronic leak detectors, dyes and dye lights, accessory tools (and it you want to do it all legally: recovery equipment), text books, etc. and then the cost of your time. If you are looking at these procedures simply for the self-satisfaction quotient then you can't place a cost on it. But, if you are looking at it from a cost standpoint then there is not benefit to go down that road; let a pro handle it and work with him. Save your money for something else, like something nice for the spouse since she let you use her credit card to buy your new ac system, maybe some golf lessons, or some wise investment with the next bull market (did I say "bull").
Old 03-23-2008, 05:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #90 (permalink)
Well as I stated at the start of this thread, there are lots of options to choose from and my "plan" has gone through numerous revisions. I had never intended to go with a full system kit from any one vendor (not that there is anything wrong with that). My first objective was to add more condenser capacity as my research says this is the #1 weakness of the 911 A/C system. Secondary objectives were conversion to barrier hoses and upgrading to higher efficiency serpentine evaporator and front condenser units.
My inital plan called for an underbelly condenser from PerformanceAire which would require re-routing of the high pressure lines so I pre-purchased a hose crimper from another Pelican (thanks Thomas) and I planned on fabricating all new barrier hoses myself.
Then I contacted Charlie at Griffiths out of curiosity for a quote on his Duehl Kuehl condensers. I was a little concerned with the clearance issues of an undermounted condenser along with concerns over lack of air flow in stop and go traffic here in ATL. I was expecting a huge price differential in the underbelly vs Duehl Kuehl system but with Kuehl's off-season pricing it was a good value. The only catch was he only sells the condenser kit with a barrier hose kit. Not exactly what I wanted at the time but after the fact, I'm glad I went in this direction from a time consideration. I've got two full weekends of work in the project without fabrication of new hoses.
Charlie's responsiveness in providing the quote and following-up by phone, email and PM here before and after the sale has been remarkable. To give equal time, I have also spoken to Ron and RennAire and Rock at RetroAir in the past and both were equally generous with their time on the phone. We are lucky to have their expertise and product options.
I chose the DD front condenser based on its size and good reviews here and I was not going to go with the ProCooler and then changed my mind at the 11th hour b/c I decided to convert to 134a (yet another change in plans) and figured the ProCooler would help. While some may argue if it is such a good product, why don't all auto makers use them? I think they don't need to b/c of condenser size and good air flow in conventional A/C systems. And finally, if Jim Sims advocates the concept of a subcooler in our cars - that's good enough for me!
My final mid stream project change was to go with a Denso factory rebuilt compressor obtained from my local MB mechanic at his cost - how could I resist.
My 21 year old compressor with 165k already past it's useful life - why risk it?
So, at the end of the day, I might have been better off in terms of $$$ to go with a complete kit but how much fun would that have been?
RE the fender rock guards, the kit is supplied with rock guard blanks to be cut and fit by the installer as the fitment from car to car may vary.
Mark
1987 911 Coupe
Old 03-23-2008, 06:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #91 (permalink)
rbuswell's Avatar
Porsche Crest Superb answers
Mark & Griff:
Fabulous answers. Keep up the good work!
1982 911SC
1987 924S
Old 03-24-2008, 06:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #92 (permalink)
Originally Posted by derkpitt View Post
Well Mark that's a good Q?
Don't really know where you would look on your side of town.
But I have a small bottle and set up to do just that job, I can load it to ya.
When your ready just give me a call and we'll set something up.
The nitrogen is dry and is great for purging and pressure testing the sys before servicing.
Bruce, I'd like to take you up on your offer as I am planning on charging next weekend - PM sent.
Thanks!
Mark
1987 911 Coupe
Old 03-24-2008, 07:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #93 (permalink)
Project Update:
I plan to charge the system this weekend. All that is left on the install is to drain any oil in the rebuilt compressor, put the correct amount of ester in (6 oz.) connect the high pressure and suction lines and, at the last possible moment, connect the high pressure lines to the ProCooler then follow the recommended evac and charge procedures.
Given all the fiddling around with the DD condenser fittings I want to make sure I did not compromise the brazed fittings causing a leak before opening the shipping vacuum on the ProCooler.
So, here's the plan:
1) Fill the compressor with oil, install and connect the H & L hoses.
2) Pressure test the system for leaks using Nitrogen, BUT bypass the ProCooler on the initial test by connecting the two high pressure ProCooler lines together using a coupler.
3) If the DD condenser connections pass the pressure leak test, connect the ProCooler lines and test again. If the first test fails, I'll have the opportunity to correct the condenser connection problem before opening the ProCooler and potentially ruining the dessicant.
I'm hoping the correct size coupler for the two #6 hose fittings will be an easy hareware store find.
Specs shown here would indicate I need a 5/8" thread coupler to join two #6 fittings.
http://www.royalbrassandhose.com/catpdf/RBH%20Air%20Conditioning%20375-402.pdf
Mark
1987 911 Coupe
Old 03-27-2008, 01:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #94 (permalink)
Mark, I just ordered it...so we'll see, I hope it is good reading. Thanks for the tip.
Good luck on getting it! I've called three times this week to see if anyone can tell me when it might ship....it's been in "picking order status" for 8 days and all customer no-service can tell me is the only thing they can do is email the supplier to find out the status and call me back....then no one calls me back WTF?
Pretty crappy internet order fulfillment service!
Hope I didn't lead you astray
UPDATE: Oh my, a call back......est delivery 4/3 but will try to expedite and should receive earlier.
UPDATE UPDATE: Just checked order status again. After 8 days in "picking order" status followed by a telephone call yesterday that is was shipping the system now shows "backordered" status !
Mark
1987 911 Coupe
Old 03-27-2008, 02:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #95 (permalink)
The Snap On Air Conditioning Training Manual arrived yesterday. It is great read for a DIY'er. Neat section on Problem Diagnosis - common problems and typical gauge readings for trouble shooting.
Also posting my desert duty condenser rail road crossing casualty here (covered in seperate thread). Think twice about lowering your ground clearance as this could happen to you too!
DD Unit installed before lines hooked up and crash bar lowered to facilitate hose connections and protect condenser
After rail road crossing
Griff's front serp condenser arrives tomorrow & I'll put everything together in stock configuration.
Weather is not cooperating in ATL for good charging conditions. We have been in the 40 -50's with rain. 134a PT charts start with an ambient range of 70 - 80. After all this work, it would be a shame to do a less than stellar job charging the system.
Mark
1987 911 Coupe
Old 04-01-2008, 02:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #96 (permalink)
Wildman Emeritus
Mark,
How big were the spacers that you used with the DD condensor, if you used spacers?
I'm trying to sort out my clearance as I am lowered. I would like to maximize clearance for obvious reasons.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 04-01-2008, 02:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #97 (permalink)
Originally Posted by Mike Andrew View Post
Mark,
I used a few addl washers on the rock guard b/c the spacers provided were not enough to lower the cage. Just measured the big washers I used to lower the crash bar at the mounting points...I had dropped it 3/4" from stock.
Mark
1987 911 Coupe
Old 04-01-2008, 03:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #98 (permalink)
Kuehl front serpentine condenser arrived today. Thanks once again for the great service. Absolutely no problems with the hose fitment.....took all of 30 minutes to install.
Here's a couple of pics of the OEM tube & fin condenser, Kuehl's front condenser and my damaged desert duty unit.
My accident this weekend may very well have been a fluke occurance, but I will rest easier now not worrying about front clearance issues! Skid plates go on next as soon as they arrive for further protection.
Mark
1987 911 Coupe
Old 04-02-2008, 07:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #99 (permalink)
Great job Mark. But it's hard to sympathize with someone putting A/C in their car when it's still 22F here!!! (just kidding of course)
O2 In Sully We Believe
Old 04-03-2008, 04:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #100 (permalink)
Closed Thread
