Throw it on the ground!
Unfortunately, I don't own an IR Thermometer but let me check with some neighbors. What I can tell you is that the suction line at the compressor was not cold to the touch at the conclusion of charging but I have not checked it after running the car on the road at higher RPMs with good airflow (but I will). The ProCooler was ice cold and sweating. Any idea what the "normal" operating temp range is for the compressor? I believe all of my high side hoses are #6 and all suction lines are #8. High side lines run from the compressor to rear deck condenser to rear wheel condenser to front of rear wheel condenser to front bumper consenser to ProCooler to Evaporator. Suction lines run from Evap to Procoooler to Compressor. Tsuter, looks like you're already in the 90's in San Antonio. How's your system cooling?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 05-13-2008 at 08:50 AM.. |
Original Owner
But I am interested in compressor temps. Not sure what they should run at. I may be a bit low on charge.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Check out this site:
http://www.climatictesting.com/Automotive%20AC%20System%20Test%20Stands.htm Says that compressors may run at 250 degrees
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Wildman Emeritus
I am still not there. A few distractions have taken precedence the last several days. I hope to wrap everything this weekend but that is iffy as it will only be 60ish here and that's a bit cool to charge.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
I see one less line in your ProCooler hose jungle than mine. Do you have a front bumper condenser - could not find the year of your car but may have missed it.
Wearing Pants
Plus the pics do not show the hi-side running from the rear condenser to drier. That was the last thing I ran. You can see the c-clamp where it is to go. It is just along-side the rest running up. The dirty hose is the gas filler overflow. Last edited by CatSkynr; 05-13-2008 at 04:48 PM.. |
Woo hoo! It's 70 and cloudy today and I was running on the Interstate earlier today. Tested Max Cool setting and med fan speed to see what she would do. Got vent temps down to 24 degrees!!!!
Pretty impressive for 134a in a 911 IMO
Wildman Emeritus
I just hope to come close to mid 30's at the end of this project. I am truly impressed with those numbers. Cold enough to keep food & drink cold.
I'm ready for summer! Picture is a little dark - 23 degrees vent temp! In garage, 75 degrees ambient, max cold, med fan speed & engine at 2000 rpm.
![]() Re-cap of new, four condenser system: OEM tube and fin rear deck condenser with 3 spal fans New barrier hose Duehl Kuehl fan assisted fender condensers (2) Kuehl Serpentine Evaporator 1/4" foam insulated and foil wrapped evap box Kuehl Serpentine front condenser Kuehl Variable Speed Fan Controller RennAire ProCooler Rebuilt Nippondenso Compressor Converted to 134a
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 05-19-2008 at 06:19 AM.. |
Wearing Pants
Finished. I connected everything up and did a 24hr static nitrogen pressure test at 175lbs. I used my oil injector with the nitrogen and put in 10 ounces of mineral oil and a slug of dye. Next day I evac'd for 3 hrs and charged everything up. At ~80deg ambient sitting in the garage I got cold enough for the compressor to cycle when it hits 32 deg. Average is 35deg, so we'll see how it works when in gets in the triple digits.
Me too. Nothing like nice weather to finish off this project that was inspired by this thread.
Living on Cape Cod, I didn’t need to improve the system too much, but I did need to take care of a very leaky compressor. New Kuehl center vent, serpentine front condenser, hi-low switch hose, receiver-dryer and rebuilt compressor. Followed Grif’s excellent instructions, flushed and vacuumed for a total of six hours (held vac at -29” Hg for over two hours) and a careful charge with 134a. Vent temps at 37° on a 75° day. All in all, a satisfying project. I still plan to seal up the evaporator box. Thanks for all the great information – I would not have attempted this without the great help here. Paul
1985 911 Carrera Moss Green Metallic Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning |
subbed, want to do this for the summer as well, or have my shop do it I mean
Sean 1988 911 Coupe Blk/Linen 1992 Mercedes-Benz 190 2.3 1999 Honda Accord LX 2003 Kymco People 50 (city killer) |
911 addict
I can't wait to finish mine- I have all of the parts on hand now and am building my "Jim Sims" subcooler presently- hopefully I will be able to do the AC install in the next week or two.
Good job to those with these low vent temps!
1987 Carrera Cab Toyota Landcruiser 500SL |
Wildman Emeritus
I have virtually everything plumbed in except the TXV & condensor connections to the Procooler which I will do just before evac. & charge. However, I hit a snag with compressor pulley interference and am awaiting a compressor with a turned down pulley from Rennnaire. So, I am still in limbo.
Wearing Pants
Well we hit 90s yesterday. With the car sitting in the sun all day and a cockpit temp in the triples, it took about 5mins and the vent was blowing 38. What I find amazing is that the condensers don’t get hot! (after ~45 minutes driving in-town) I can literally lay my hand on the deck lid condenser and it’s just warm, compared to the old York days. Same with the wheel-well; although I can’t really lay my hand on it due to space, to the finger touch they are just warm. The compressor definitely gets hot. The pro-cooler is cold and you can feel a temperature differential between the inlet and outlet of the low-side into the sub-cooler. So far I am really happy. As screwed up as it sounds, I can’t wait for a day of triple digits to really test this system out.
Well, sometimes it’s the simple things.
Checking the vent temperature -- while the front trunk lid was open -- to make sure I hadn’t ruined something new while re-sealing the evaporator box to replace all the foam that had gone to dust, I noticed I could see daylight through the center dash A/C vent. Somewhere along the way in the last 24 years, the duct to the center vent had slipped off the vent. Reaching around from the front, but mostly reaching in through the clock hole, I was able push the vent back into place. I had always wondered why it didn’t seem like a lot of air was coming through the vent – much better now. Paul
1985 911 Carrera Moss Green Metallic Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning Last edited by PSJoyce; 05-28-2008 at 01:15 PM.. |
Man, you guys are awesome!
My '89 needs a new compressor and evaporator; after a professional inspection. They actually said everything else was fine (sure)... I would love to do this full project but lack the time and/or $$. Any Pelican experts in Socal that want to do this as a side project on my car someday? Great project for someone out of work or retired that has major skills!! ![]() Since I have a Cab, this is a low priority project, but would be really nice...
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
A/C work is not difficult. You can do the vast majority of it yourself. The only part that is above the average home mechanic is the vacuum & charging. Hire a pro for that part if you don't have the knowledge & equipment. It all comes down to how much COLD air is worth to you.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
That's what I plan to do but where is there a very good AC shop that knows the older (e.g. 1989) Porsches and follows all the evac and charge proceedures mentioned in this thread and others... in northern CA or do I need to drive to LA to get the fricken thing done correctly?
