Rennch on YouTube
How did you "hang" your Flowmaster muffler?
I have a dual-in, dual-out Flowmaster 80 series muffler that I need to mount. Anyone have pics of how they mounted theirs?
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Wer bremst verliert
Mine hung just like the standard..no pics on this laptop but searching on my name and exhaust should show up.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Rennch on YouTube
The straps were long enough?
Wer bremst verliert
no, just longer straps
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Funny, I just did this yesterday on my track car... I used the OEM bracket and bent it back. I used a piece of scrap Al to make a J and attached it to the two lower bolts that hold the engine to the rear cradle. I had to bend the OEM bracket to "straighten" the muffler up since I was concerned about the intake pipes touching the exhaust pipes.
Using (4) 5"dia. hose clamps and there is no movement at all. I'm happy. Including pictures. It was my first time welding, and even thought the welds are not too pretty, they will hold. I bought the muffler (best price @ Amazon), (4) 90deg pipes and a u pipe to get the right angle needed for the connection from the headers up to the muffler intake (Summit racing). Total cost about $260 including, 02 bung, 2 hose clamps, gaskets and flanges. Had to buy a welder, but it was something that I always wanted to tackle... Borrowed a Sawzall for the cuts and a grinder for final shaping. I think it came up pretty good and it took about 5 hrs! Enjoy... Lou ![]() ![]() ![]() ![]()
'76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ |
here's mine
I welded a plate on the back of the muffler with 2 holes towards the bottom. It mounts to the 2 lower case studs.
Gary R. Last edited by GaryR; 03-23-2008 at 08:50 AM.. |
Bill,
I believe those are the same headers that came with my car, who are they by? Any of you flowmaster guys have YouTube video? I'm interested in seeing what this sounds like. |
Just longer SS hose clamps. Quick. Easy.
I (actually Scotty at the local muffler shop) used the same approach as most of the previous responses - a welded on bracket attached to the lower studs on the engine. I had replace the short studs with longer ones to mount the jackpad/towhook and there was enough meat left on the stud to mount the Flowmaster. It can be dropped without removing the rear valance.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Loose nut bhind the wheel
So you guys are sending the exhaust into each side and out each side. Isn't one side of that muffler a dual inlet and the other side a dual outlet? How does that affect the sound and exhaust flow or is it a special cross-flow muffler. Can you post a part #. Thanks.
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 Last edited by eapcpa; 03-23-2008 at 08:37 PM.. |
Excellent photo's.
Len911, did you weigh that before mounting by chance?
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
Rennch on YouTube
Guys, thanks so much. Somehow I missed these responses.
Lou, you might have inspired me to take a crack at welding this up myself. Did you eventually seam-weld the tubes after you tacked it?
Rennch on YouTube
Bill V...where did you get the extra long muffler straps?
Rennch on YouTube
Ed, mine is a Flowmaster 80 Series, 2 in, 2 out. Flowmaster 42582 is the part #.
Total weight was 24lbs 9oz versus my Supertrapps 14lbs 8 oz. So we are talking about 10# difference. Hopefully I'll get some more torque... Noticed my car was idling really rich after install. Sent for some smaller idle jets for the 46IDAs... Yes I did weld up all the seams and flanges, it is not going anywhere
Lou
I've used the same header set on a 964 and 2 993 engines mounted in the C3 chassis.
Probably Fabspeed, it came w/ their header muffler kit.
