vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Diagnose Spark Plug - Something's Wrong
Attached is a plug I just removed from my rebuilt motor - about 600 miles - and my milage (MPG) is horrendous. Any ideas?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-23-2008, 10:43 AM
Now you need to find out why it's running so rich. Things to check might begin with the frequency valve operational, 02 sensor, dome light working? Or take it to a wrench who's familiar with these hints.
Old 05-23-2008, 01:16 PM
David's Avatar
Do all the plugs look the same?
Old 05-23-2008, 04:37 PM
vesnyder's Avatar
I actually ran it on teh freeway then shut it down without taking it to idle and snapped th epic then - so I only checked one plug. Whan I changed the plugs about 200 miles ago they were all similar.
Vance
Old 05-23-2008, 04:40 PM
Zeke's Avatar
That explains to me why the plug and black and white at the same time. Is the O2 sensor hooked up? I guess you ought be chasing idle mixtures because the freeway RPM is actually lean.
that didn't make any sense, did it?
Old 05-23-2008, 05:34 PM
abit off center
cgarr's Avatar
Get more miles than 600 on it. I assume this is you SC and not the 914?
______________________
Craig
G2Performance
Old 05-23-2008, 06:46 PM
Maybe its the angle of the photo but that gap looks a little tight, are you getting higher then normal engine temps?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-24-2008, 03:02 AM
