AutoBahned
RWebb's Avatar
Torque Values with Loc-tite
"Our liquid anaerobic threadlockers mimic oil at the point of assembly so that you don't gall stainless of soft metals.
Suggest backing it off 10% of the dry spec value. Treat the assembly as a lubricated fastener when tightening."
- from James Adams, technical specialist at Loc-tite (Henkel)
Old 06-06-2008, 02:29 PM
barney911rs's Avatar
hmm, good info Randy
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 06-06-2008, 03:22 PM
Immature Member
dentist90's Avatar
If LocTite sets anaerobically... how come it doesn't set in the tube??
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-06-2008, 03:25 PM
Peter Zimmermann's Avatar
What application are we talking about? Rod bolts/nuts go together without threadlocker, as does all of the crank case hardware, chain box hardware, etc. On an aluminum case LocTite 574 is used on case halves, and again on the cam housing to cylinder head contact point. No change in torque has ever been mentioned or discussed using 574.
In the case of threadlocker, what would we use it on that's not micro-encapsulated from the factory (P/S & M/S trans nuts, rear suspension hardware on 911s fitted with multi-link components, nylok nuts in many applications, locking copper nuts for intake manifolds, upper strut/shock nuts and countless other special and non-special fasteners. I guess what I'm asking is why should this product all of a sudden be needed when it hasn't been for the past xxx years. Just respectfully curious???
Keep the Shiny Side UP!
Pete Z.
Old 06-06-2008, 03:55 PM
AutoBahned
RWebb's Avatar
the query involved generic fasteners
as to the need, it can be useful for vibration - anybody who has run VW's across the desert or on really bad roads thinks of Loctite as an elixir of the gods
Old 06-06-2008, 04:10 PM
Porsches do not need loctite? With all due respect, they only don't need em if you don't drive em.
I've learned it's better to be safe than sorry, and I do not care if purists think it's not necessary. I'll remember the 10% reduction number, which is good to know.
Intake manifold bolts, cv joint bolts (even with the correct washers), Rennline adjustable gas pedal, front suspension mounting bolts, front swaybar mounting nuts, center console sheet metal screws, inner panel sheet metal screws, brake caliper mounting bolts, exterior thermostat "thermostat saver", sunvisor clamp screw, etc.
There are a lot of fasteners that come loose on Porsches. After a long drive, there are a lot of bolts that you just have to take a torque wrench to and check for tightness.
So this is good to know.
Old 06-06-2008, 04:39 PM
Immature Member
dentist90's Avatar
...anybody who has run VW's across the desert or on really bad roads thinks of Loctite as an elixir of the gods
EWWW! No matter how hot and thirsty you get, don't drink the LocTite!!
Old 06-06-2008, 04:40 PM
Warren Hall Student
Bobboloo's Avatar
Loctite has been used for years on the cylinder studs. It serves a dual purpose. Holds the stud in the case and prevents corrosion.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 06-06-2008, 04:59 PM
mca mca is offline
mca's Avatar
Interesting ... and nobody has responded.
Good question.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 06-06-2008, 05:01 PM
Well, of course, but that has nothing to do with this thread. Head stud installation is done to a length spec, not a torque spec.
Pete Z.
Old 06-06-2008, 05:55 PM
AutoBahned
RWebb's Avatar
What about as an endodontal rinse?
Old 06-06-2008, 08:11 PM
AutoBahned
RWebb's Avatar
"I'll remember the 10% reduction number, which is good to know."
depends on the bolt - whether the spec is dry or oiled
only a 10% diff., but I'm still not sure what P AG has spec.d
Old 06-06-2008, 08:14 PM
I thought the convention was that all values were dry unless specified. I've been assuming the Bentley manuals were quoting dry numbers with clean threads of course.
Old 06-06-2008, 08:22 PM
AutoBahned
RWebb's Avatar
I've heard that for Porsche, and/or for German car in general. Not sure if true tho.
Old 06-06-2008, 08:37 PM
Wer bremst verliert
JohnJL's Avatar
I was just assembling a case today and thinking the same thing about "why doesn't the 457 cure in the tube?"
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-07-2008, 02:06 AM
Wer bremst verliert
JohnJL's Avatar
Maybe it initially oxidizes and changes chemically and then becomes anaerobically curing?
Old 06-07-2008, 02:07 AM
An engine builder once told me that if it doesn't get anti-seize then it should get Loctite.
Richard Newton
Autocross Performance Handbook
Ultimate Garage Handbook
Old 06-07-2008, 02:57 AM
Diss Member
Quicksilver's Avatar
Loctite only hardens in the absence of air (anaerobic). If you take a brand new tube or bottle of thread locker and shake it you can feel the air in the package. They never fill the packages more then halfway.
To dive farther into it:
What actually catalyzes the curing reaction is two part. It must have a lack of oxygen and be in contact with metal with active ions. Iron, non stainless steels, nickel, brass, bronze, aluminum alloys, copper, etc are all metals with active ions.
Anodized aluminum, pure aluminum, stainless steel, titanium, galvanized steel, zinc, cadmium, magnesium, chemical black oxide, gold, silver, etc are examples of metals without active ions. Most of your corrosion resistant metals or platings get their corrosion resistance from the lack of free ions. Basically most plating won't kick the curing process so it is a lot better if at least one of the exposed metals is an active metal. I have found that it will cure if you are using only metals from the "non active" list but it is pretty slow.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-07-2008, 03:09 AM
Slumlord
Porsche_monkey's Avatar
Blue loctite never seems to dry in the tube. But if you leave red loctite in the nozzle it will harden. If I let mine sit too long it has to be drilled out.
Old 06-07-2008, 06:53 AM
Zeke's Avatar
I have a feeling after reading this forum for many years that if you took all the torque wrenches from everyone's tool boxes and threw them in one pile, they would differ in calibration by 10 %. What's my point? That many motors have been assembled with torque values in a range of +- 10%. And most all of them live.
Is it possible that the value given for a specific bolt/nut is a target and not an absolute? I mean the charts don't seem to take in to account ALL of the variables like different manufacturers (slightly different metal composition),etc.
Copied from the Net:
Joe Greenslade is President of Greenslade and Company, Inc. located in Rockford, Illinois. His firm specializes in providing manufacturing tooling and inspection equipment to suppliers of screws, bolts, rivets, and nuts
throughout the world.
The table in this article shows that by using this formula a 1/2-13 Grade 5 plain bolt should be tightened to 82 foot pounds, but the same bolt that is waxed only requires 41 foot pounds to tighten the same tension. A perfect 1/2-13 Grade 5 waxed bolt will break if it is tightened to 81 foot pounds because the K factor is drastically lower. The bolts are fine, but the application changed. Suppliers need to understand this and be able to educate their customers to resolve this common customer complaint about breaking bolts.
"What torque should I use to tighten my bolts?" Keep in mind this is only an estimated value. It may provide satisfactory performance, but it also may not. Every application should be evaluated on its own to determine the optimum torque value for each application. Major bolt suppliers should have tension indicating equipment necessary to help their customers determine the appropriate tightening values for their specific applications. Keep in mind that if the lubricant on a bolt and nut combination is changed, the tightening torque value must be altered to achieve the desired amount of bolt tension.
Old 06-07-2008, 07:12 AM
