AutoBahned
Torque Values with Loc-tite
"Our liquid anaerobic threadlockers mimic oil at the point of assembly so that you don't gall stainless of soft metals.
Suggest backing it off 10% of the dry spec value. Treat the assembly as a lubricated fastener when tightening." - from James Adams, technical specialist at Loc-tite (Henkel) |
hmm, good info Randy
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
Immature Member
If LocTite sets anaerobically... how come it doesn't set in the tube??
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
What application are we talking about? Rod bolts/nuts go together without threadlocker, as does all of the crank case hardware, chain box hardware, etc. On an aluminum case LocTite 574 is used on case halves, and again on the cam housing to cylinder head contact point. No change in torque has ever been mentioned or discussed using 574.
In the case of threadlocker, what would we use it on that's not micro-encapsulated from the factory (P/S & M/S trans nuts, rear suspension hardware on 911s fitted with multi-link components, nylok nuts in many applications, locking copper nuts for intake manifolds, upper strut/shock nuts and countless other special and non-special fasteners. I guess what I'm asking is why should this product all of a sudden be needed when it hasn't been for the past xxx years. Just respectfully curious???
Keep the Shiny Side UP! Pete Z. |
AutoBahned
the query involved generic fasteners
as to the need, it can be useful for vibration - anybody who has run VW's across the desert or on really bad roads thinks of Loctite as an elixir of the gods |
Porsches do not need loctite? With all due respect, they only don't need em if you don't drive em.
I've learned it's better to be safe than sorry, and I do not care if purists think it's not necessary. I'll remember the 10% reduction number, which is good to know. Intake manifold bolts, cv joint bolts (even with the correct washers), Rennline adjustable gas pedal, front suspension mounting bolts, front swaybar mounting nuts, center console sheet metal screws, inner panel sheet metal screws, brake caliper mounting bolts, exterior thermostat "thermostat saver", sunvisor clamp screw, etc. There are a lot of fasteners that come loose on Porsches. After a long drive, there are a lot of bolts that you just have to take a torque wrench to and check for tightness. So this is good to know. |
Immature Member
Warren Hall Student
Loctite has been used for years on the cylinder studs. It serves a dual purpose. Holds the stud in the case and prevents corrosion.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Good question.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Well, of course, but that has nothing to do with this thread. Head stud installation is done to a length spec, not a torque spec.
AutoBahned
AutoBahned
"I'll remember the 10% reduction number, which is good to know."
depends on the bolt - whether the spec is dry or oiled only a 10% diff., but I'm still not sure what P AG has spec.d |
I thought the convention was that all values were dry unless specified. I've been assuming the Bentley manuals were quoting dry numbers with clean threads of course.
AutoBahned
I've heard that for Porsche, and/or for German car in general. Not sure if true tho.
Wer bremst verliert
I was just assembling a case today and thinking the same thing about "why doesn't the 457 cure in the tube?"
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Wer bremst verliert
Maybe it initially oxidizes and changes chemically and then becomes anaerobically curing?
An engine builder once told me that if it doesn't get anti-seize then it should get Loctite.
Richard Newton Autocross Performance Handbook Ultimate Garage Handbook |
Diss Member
To dive farther into it: What actually catalyzes the curing reaction is two part. It must have a lack of oxygen and be in contact with metal with active ions. Iron, non stainless steels, nickel, brass, bronze, aluminum alloys, copper, etc are all metals with active ions. Anodized aluminum, pure aluminum, stainless steel, titanium, galvanized steel, zinc, cadmium, magnesium, chemical black oxide, gold, silver, etc are examples of metals without active ions. Most of your corrosion resistant metals or platings get their corrosion resistance from the lack of free ions. Basically most plating won't kick the curing process so it is a lot better if at least one of the exposed metals is an active metal. I have found that it will cure if you are using only metals from the "non active" list but it is pretty slow.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Slumlord
I have a feeling after reading this forum for many years that if you took all the torque wrenches from everyone's tool boxes and threw them in one pile, they would differ in calibration by 10 %. What's my point? That many motors have been assembled with torque values in a range of +- 10%. And most all of them live.
Is it possible that the value given for a specific bolt/nut is a target and not an absolute? I mean the charts don't seem to take in to account ALL of the variables like different manufacturers (slightly different metal composition),etc. Copied from the Net: Quote:
Thread Tools | |
Rate This Thread | |
