9.8 3.0 p/c where to fine a set for my rebuild
Is Andial the only source for these elusive piston and cylinders?
currenly have a 1978 3.0 in my 1975 Carrera. Thanks, Craig |
Also look into Nickies as an alternative to Mahles if you want something other than the standard configurations http://www.lnengineering.com/
Robert Currently Porsche less (but the wife has 2) |
Less brakes, more gas!
You may find it easier to get a whole newly manufactured set rather than an OEM set. When I was looking to replace my one blown piston it took me months to find the right one and then it cost me $250... used... I never found a whole set, but I have seen 1 or 2 since then.
Best regards, Michael
![]() ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Thanks, for info. These 9.8 's P/C's are expensive!
That's why I went with a 3.2.
But if you want the 9.8, 3.0 I too would go with ln engineering. Everything I've seen of theirs was pure top notch.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
You expected otherwise?
JMO but if you are rebuilding a 3.0 w/ no constraints by class rules, you might as well use 98mm Motorsports Mahles, they aren't that much more expensive
Where do you find the mahle motorsports 3.0 or the In eng. for that matter?
thanks, I am buliding a street motor to run on 91 oct. gas with some open track days. If a 3.2 conversion will work with 91 gas I would also go that way. I have a 78 3.0 with matching heads and runners |
Look on the next page from where I sent you last time
Hilbilly Deluxe
You don't want a single plug 9.8:1 98mm bore on California's piss-water 91 octane gas.
Tom |
Thread Tools | |
Rate This Thread | |
