911s get great gas milage
mike gilbert's Avatar
Need help with 914 keys, i will explane wrong forum(EASY?)
hey chaps, im purchasing a 914 that has no key.does the ignition have the same tummbler code for the door?can i pop a door cylinder and have it keyed to work instead of the ign. switcht?i have to take the panels off anyway and rather not mess with the ignition.i dont even know if a 914 uses 1 key or 2..just planing ahead..the reason i posted here is because i know there are a lot of 914 owners here as i have become a 2 pcar owner now a 83sc coupe and 72 914 1.7..there are only 2 people in the 914 forum..thanks for understanding my wrong forum post..mike
Old 08-04-2008, 06:42 PM
Danny_Ocean's Avatar
www.914world.com
Old 08-04-2008, 06:44 PM
Zeke's Avatar
914's use the same red key/black key system as an early 911. Since it's essentially a Targa, the red key will operate all locks, the black key only the doors and ignition. You should have the red key for the glove and the front trunk.
I might have that bassackwards, but you get the point. It's called a valet key that does only the doors and ignition.
Old 08-04-2008, 06:55 PM
Yep that is backwards. The BLACK key is master and operates everything. The red key is the "valet" key and only does the doors and ignition. That way you can lock the glove box, front trunk & rear trunk and the valet has no access.
Old 08-04-2008, 06:57 PM
HarryD's Avatar
Assuming the PO did not rekey one of the other locks (i.e. the ignition key is different than the other keys), then a decent locksmith will be able to make a key from one of your tumblers.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-04-2008, 07:05 PM
well i dont have either key.by what your saying i can take the trunk cylinder out and get it keyed to work all locks?
Old 08-04-2008, 07:06 PM
HarryD's Avatar
It should work UNLESS the PO changed some of the locks and did not rekey them to match the Ignition key. Prolly worth a try. an alternative is to go to the Porsche Dealership with the serial number and proff of ownership and see if they can look up the key number and make one that way.
Harry
2020 MB E350 4Matic
Old 08-04-2008, 07:11 PM
its a one owner car so maybe not i hope.does anyone know for sure what i need to do, thanks
Old 08-04-2008, 07:19 PM
HarryD's Avatar
I would first try a key made from one of the other locks. The glove box lock is the easiest to get out.
Harry
2020 MB E350 4Matic
Old 08-05-2008, 09:27 PM
