3.2 supersport - how easy to replace discs/rotors and pads?
Hi folks. I have an '87 3.2 supersport with 930 brakes and I was thinking of spending a few weekends putting new discs and pads on. I've searched for a techical article on how to replace the brake discs, but can't find one. Is it to much of a job without special tools?
Old 08-10-2008, 08:35 AM
Nine9six's Avatar
Gerard,
Its a simple and straight forward job, with no exotic tools needed.
While you are in there, you may want to think about turbo tie rods, and dot stainless steel brake lines
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 08-10-2008, 09:18 AM
Hardest part of the job is getting the dust caps off the hubs in the front. The second hardest part is coughing up the cash for the rotors.
Old 08-10-2008, 09:23 AM
re. dust caps - I didn't like how hard they were to pull off so I made this..
has worked fine for a number of years.
Old 08-10-2008, 09:37 AM
Somatic Negative Optimist
Gunter's Avatar
LARGE channel-lock pliers will take the grease cap off; take a firm grip perpendicular and wiggle up and down.
Connected with replacing rotors is to decide on replacing the front bearings depending on condition and mileage.
And how are the calipers?
Time for a rebuild?
Sounds like you need the Bentley Repair Manual for Carreras.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-10-2008, 10:02 AM
Gerard,
Great advice from everyone above,....
I would strongly suggest that you have the Bentley Carrera manual on hand as that provides the basic information.
You didn't say how many miles are on your car so its difficult to make specific recommendations however, you should plan on cleaning, inspecting and repacking your front wheel bearings and replacing the inner seals.
Those late 930 rotors (non-floating) are quite inexpensive as are good pads.
You will need some basic hand tools and an accurate 3/8" drive Torque Wrench to properly attach the new rotors to the hubs.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-10-2008, 10:21 AM
Elombard's Avatar
what is a 3.2 supersport? Is that a euro designation for a 84-86 carrera or something more exotic?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 08-10-2008, 10:33 AM
Sorry. It's the turbo-bodied 3,2 - with the turbo's brakes and suspension.
Old 08-10-2008, 11:12 AM
MEMBER # 930
waynesco1's Avatar
M491 option
Old 08-10-2008, 11:59 AM
Thanks for such speedy advice. I think I'll invest in the Bentley manual and then decide whether I'm brave enough to give it a go.
Old 08-10-2008, 01:12 PM
Originally Posted by Gunter View Post
LARGE channel-lock pliers will take the grease cap off; take a firm perpendicular and wiggle up and down.
Time for a rebuild?
Muffler clamps on the dust caps will give you something to lever against to get them off as well.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 08-10-2008, 03:54 PM
