zbph10's Avatar
What is this? It's making a lot of noise
I'm a new turbo owner and this thing is making a heck of a racket while the cars ignition is either in the ACC position or if the car is running. It's somewhat intermittent. Car is a 91 turbo. It runs and drives fine, just noisy.
What needs to be done?
Brian
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 08-30-2008, 08:23 AM
burgermeister's Avatar
I have NEVER seen a Turbo or owned one, but I'm curious. Perhaps something involved in oiling said turbo's bearing?
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 08-30-2008, 08:44 AM
zbph10's Avatar
BTW It's on the drivers side exhaust piping.
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
Old 08-30-2008, 09:44 AM
Oh Haha's Avatar
The Turbo forum would be a better place for this question.
You should post over there as well.
That is the wastgate, BTW.
Can you describe the noise? Are you getting full boost?
Pacific Blue
Wayne
Old 08-30-2008, 09:50 AM
Crotchety Old Bastard
RarlyL8's Avatar
That is the waste gate and catalytic converter / heat shield form a C2T.
I don't know why it would be making a noise unless the heat shield is vibrating against something.
Old 08-30-2008, 09:59 AM
What controls wastegate actuation? Could it be getting erratic inputs or maybe be unable to function properly, the noise being the wastegate attempting to position itself.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 08-30-2008, 10:23 AM
Positive pressure in the intake manifold, aka "boost". The control input is connected above a big diaphragm connected to a big valve with a big spring.
When there is sufficient pressure (factory setting is .7 or .8 bar) above the diaphragm to overcome spring pressure and open the valve, it dumps exhaust gas before it drives the hot side of the turbo in order to regulate the intake manifold pressure.
You cannot get this without load on the motor - e.g. revving the car to any RPM you like at a standstill is unlikely to build significant boost.
What sort of noise? Rarly's "heat shield rattling" sounds like the best explanation.
If it does it with the ignition to ACC and the car not running, are you sure it's coming from there? The fuel pumps make a racket, but yours shouldn't run until the plate on the air metering moves off the stop...
'77 S with '78 930 power and a few other things.
Old 08-30-2008, 10:43 AM
The heater blower motor is directly above the wastegate, sure it's not that?
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-30-2008, 11:11 AM
+1 what Britrench said....if the car engine is NOT running but key is in ACC position, and you hear the noise- try turning off your heat and blower/fan to see what happens.
otherwise +1 what spuggy and rarly said.
good luck.
1985 redslope 930, 8:39 RP, S cams, B&B dual out muffler, IA Fuel Dist. Sitting on shelf awaiting installation: IA HF turbo, GSF headers(no heat), 46mm wastegate.
1971 911T Targa. needs alot of work(understatement).
Old 08-30-2008, 02:46 PM
zbph10's Avatar
It's not doing it today so next time it makes the noise I'll try it.
Thanks for the ideas!!
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
Old 08-30-2008, 05:34 PM
zbph10's Avatar
I started removing fuses until the noise went away and it was the drivers side blower motor. I pulled it out and it was completely shot.
Thanks for the help
Brian
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
Old 11-09-2008, 10:38 PM
