Designer King
Paulporsche's Avatar
MSD Spark Plug Gap
Surprisingly a search did not yield the type of info I was looking for.
Those w/ SC or 3.2Carrera engines and an MSD CDI: What plug gaps are you running and w/ what heat range plugs for street cars?
I have always used 7 range plugs. W/ an MSD does a gap of .040 or .045 " sound right?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-01-2008, 07:14 PM
dion914-6's Avatar
MSD Install, now no power
I think your answer is in this recent discussion.
Dion
Dion
2002 Boxster S
1999 M3
Old 09-01-2008, 07:21 PM
T77911S's Avatar
good question paul, i am testing a set of W4cs plugs out of my brothers 930. i was going to post basically the same question/ results.
like you, i was using W7's. i am doing this to test detonation and fuel octane.
so far i have had good results. i am using 87 octane, before, i HAD to use 92+ or it would ping. it starts good, runs good with no fouled plugs. i pull 2 out every few days and check them and they even look good, despite they were used.
next i am going to bump the timing up a tad to see where it pings.
i have not run it above about 4200 because of a miss,( i have a 914 rev limiter in there and i think it is coming in too soon). i think i am going to end up using W5 plugs in the end.
i also have an MSD, i have set the gap as big as .065.
before i learned about about plugs, i thought hotter meant more power. if the plug gets too hot, it can ignite the fuel early causing detonation.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-02-2008, 04:43 AM
Designer King
T77911S,
You said you have used a gap as wide as .065. Have you settled on that, or is it some other figure?
Paul
Old 09-02-2008, 12:47 PM
Ask Steve Weiner. porsche@rennsportsystems.com. The fabulous thing about Steve is that he will answer you in detail even though he charges his real customers triple digit rates.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-02-2008, 03:14 PM
dshepp806's Avatar
+1 on this,.....big bang for the buck, too.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-02-2008, 07:19 PM
Designer King
Thank you. I have sent a request to Steve.
Paul
Old 09-02-2008, 07:35 PM
Paul,
I have MSD Coil, Box and Wires, I am running NGK BP6ES with a .065" gap and running 87 octane, I tried running cooler plugs (4's) for whatever reason but my engine temperature went up, and when I opened the gap up it cooled down but seemed to lose a bit of umpth, I ended up sticking with the BP6ES and experimented with gaps between .045" to .065" the lower gap settings give higher engine temps and less power.
Edit:
NGK : Lower number = Lower heat dissipation
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Last edited by snbush67; 09-04-2008 at 12:38 PM.. Reason: NGK VS. Bosch Plug numbering
Old 09-03-2008, 12:56 AM
T77911S's Avatar
Originally Posted by snbush67 View Post
Paul,
Shane
interesting. i have W4's in now and my temps seem to be a little higher. i am thinking maybe the more heat the plugs are dissipating into the heads is making the temp go up, but then if they dont dissipate that heat then it is staying in the plug and could that cause spark knock?. oh what to do what to do.
i guess i need to put the W7's back in and check temps.
paul, i think i went back down to around .045, maybe a tad bigger.
RACE CAR:: sold
Old 09-03-2008, 10:02 AM
dlagerstrom's Avatar
T77911s, I think you need to be careful about comparing Bosch and NGK heat numbers. As I understand it, NGK hotter is lower and Bosch is the opposite. I don't think you can compare.
Shane or anybody, can you explain when you need the resistor type plugs and when you don't? I see Shane is using the BP6ES as opposed to the BPR6ES which our host has and the difference is R is a resistor plug. What gives and what should you use???
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 09-03-2008, 10:27 AM
Max Sluiter
Flieger's Avatar
Resistors in the plugs help suppress radio frequency interference in the same way that resistors in the plug wires do. This is to prevent static noise on ausio systems and also protects and electronics like computers.
If you don't use the radio and run CIS,MFI,carbs (not Motronic), you can loose the resistors and the wires may last a little longer and you will have a little higher voltage at the plug. This gives a more vigorous arc that can bridge a wider gap but also will erode the electrodes on the spark plug a little faster.
The resistance values are small enough that these effects will be relatively small.
Old 09-03-2008, 11:27 AM
Found this excellent explanation:
http://www.ngksparkplugs.com/tech_support/spark_plugs/p2.asp?mode=nml
It appears that NGK lower numbers mean higher temps as stated above I guess that explains my issues with the 4's.
Old 09-03-2008, 09:49 PM
This one too, it explains gapping and heat:
http://www.ngksparkplugs.com/tech_support/spark_plugs/installation/index.asp?mode=nml
Old 09-03-2008, 10:22 PM
T77911S's Avatar
yes, your are correct, they are backwards. i was only refering to heat ranges I was using. shane said he used a cold "4", i assumed it was a bosch even though he referenced am NGK later.
RACE CAR:: sold
Old 09-04-2008, 04:23 AM
