read the last few of posts again. often as simple as a blown interior light fuse. the relay is the next likely suspect. when the FV isn't working, you go very lean. seems like that's what you have.
206 637 4071
Old 10-23-2008, 11:53 AM
Originally Posted by Shane Van Wey View Post
Can you use that one with everything in it's normal place?
no.
206 637 4071
Old 10-23-2008, 11:55 AM
SCWDP911's Avatar
Originally Posted by john walker's workshop View Post
no.
Thanks... I thought it looked a little fat on top.
Shane
- 1984 928S
Old 10-23-2008, 12:51 PM
dome light
Hey the clock is running , does that count? As for the dome lights, maybe their just burned out.
Theres two small boxes down by the big box under the passenger seat.
One is 1" cube and is the relay i think. Can i check the voltage their?
The other is the size of a pack of cigarettes.
Can you adjust the mixture with that big rubber intake header in place>?
Old 10-23-2008, 01:02 PM
1" cube. if the interior light fuse is good you will have voltage in but maybe not out. check the 87 and 87b for voltage. if you don't get voltage there, you can make a jumper lead and simply give voltage to the 87 and 87b terminals in the relay plug. for test purposes.
206 637 4071
Old 10-23-2008, 01:18 PM
WUR with vacuum.......
Originally Posted by T77911S View Post
if your WUR has the vacuum enrichment, which i think it does, it could be that it is not working properly. it acts like an accelerator pump on a carb.
also check timing and make sure the advance is working.
do you have a pop off valve?
what led up to the car running bad? all of a sudden, recent work?
T77,
I believe that CIS (SC) engines with lambda sensor have WUR with no vacuum enrichment line. WUR's (-072 & -090) do not have vacuum enrichment which are OEM for these engines unless replaced by another type WUR.
Could someone say otherwise? Thanks.
Tony
Old 10-23-2008, 04:17 PM
Daviboy's Avatar
so how do you get that one pictured into the hole with the engine in the car?
A bit of jiggery pokery and it goes just need to wiggle it in between the boot and the injector lines but it does go I have done it.
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 10-24-2008, 12:45 AM
Daviboy's Avatar
Shane yes it is a bit tricky getting it in the hole but it is possible
Davy
03 996 C4S
Old 10-24-2008, 12:47 AM
Daviboy's Avatar
Here it is again pictured with the CIS back in the car
Davy
03 996 C4S
Old 10-24-2008, 12:53 AM
Todays plan
Relay is available about an hour south, so Im making the trip to buy it and hopefully fix the FV. And if that doesnt work ill start tracing the voltage.
The wur has a vacuum line on my 81 sc. The wur was removed, cleaned, i check the resistance 9.9 ohms, did the fuel pressure tests, all good, and replaced the wur vacuum line which i think had minor leaks, but didnt seem to make a big difference.
If they can find the enrichment tool I'll try that too.
Old 10-24-2008, 01:34 AM
Designer King
Paulporsche's Avatar
Tony, 81 White and T77911S,
The WURs for 80 and 81-83 don't have the vac enrichment. There is an atmosphere line @ the top.
Someone could still have one w/ vac as I do on my car, but you wouldn't use the lambda control then.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-24-2008, 05:23 AM
