read the last few of posts again. often as simple as a blown interior light fuse. the relay is the next likely suspect. when the FV isn't working, you go very lean. seems like that's what you have.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-23-2008 at 11:57 AM.. |
no.
Thanks... I thought it looked a little fat on top.
Shane - 1984 928S |
dome light
Hey the clock is running , does that count? As for the dome lights, maybe their just burned out.
Theres two small boxes down by the big box under the passenger seat. One is 1" cube and is the relay i think. Can i check the voltage their? The other is the size of a pack of cigarettes. Can you adjust the mixture with that big rubber intake header in place>? |
1" cube. if the interior light fuse is good you will have voltage in but maybe not out. check the 87 and 87b for voltage. if you don't get voltage there, you can make a jumper lead and simply give voltage to the 87 and 87b terminals in the relay plug. for test purposes.
WUR with vacuum.......
I believe that CIS (SC) engines with lambda sensor have WUR with no vacuum enrichment line. WUR's (-072 & -090) do not have vacuum enrichment which are OEM for these engines unless replaced by another type WUR. Could someone say otherwise? Thanks. Tony |
A bit of jiggery pokery and it goes just need to wiggle it in between the boot and the injector lines but it does go I have done it.
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
Shane yes it is a bit tricky getting it in the hole but it is possible
Here it is again pictured with the CIS back in the car
Todays plan
Relay is available about an hour south, so Im making the trip to buy it and hopefully fix the FV. And if that doesnt work ill start tracing the voltage.
The wur has a vacuum line on my 81 sc. The wur was removed, cleaned, i check the resistance 9.9 ohms, did the fuel pressure tests, all good, and replaced the wur vacuum line which i think had minor leaks, but didnt seem to make a big difference. If they can find the enrichment tool I'll try that too. |
Designer King
Tony, 81 White and T77911S,
The WURs for 80 and 81-83 don't have the vac enrichment. There is an atmosphere line @ the top. Someone could still have one w/ vac as I do on my car, but you wouldn't use the lambda control then.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 10-24-2008 at 05:26 AM.. |
