Need Feedback
![]() I had a problem uploading the photos. As you can see there is a standard rear bumper pad. The two smaller objects are replacement pads which use the existing holes and mounting hardware. The stock pad weights 7.3 pounds compared to 1.1 pounds for the replacement. Feedback
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... Last edited by si Banker; 10-19-2008 at 08:49 PM.. |
OK, what are you doing si?
Shane - 1984 928S |
Bumper pad
Thinking of making some of these. They would imo look much better that the oem pads and would not require and modifications.
Just looking for feed back
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
I would have to see them on a car. I cannot see it yet in my brain. But worth looking at for sure...
Shane - 1984 928S |
Member 911 Anonymous
Yeah let's see them on!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Great idea, (bolt on weight loss
) are they set up with the lights?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
THE IRONMAN
Very...very interesting substitute...Please keep us informed...Subscribed.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> Last edited by Zef; 10-20-2008 at 12:25 PM.. |
Bumper Pad
The license plate lights will used a product called Lite Bolts, which have a light source built into a bolt. These would be included with the pads along with the necessary electrical connectors.
The idea is to get rid of the large pads but at the same time be able to return the car to original if one wants to do so. I wanted to clean up the rear bumper as much as possible. The pads can also be painted to match the body color. There will also be a replacement for the smaller Euro pads.
I just went with saving the whole 7.3 ... Are you going to mass produce these? Any idea of the cost?
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
MBruns for President
I like em!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I'd put more bevel on the edges, so they're more streamlined. Also, I'd consider making them hollow (so they look like the letter "O", which would give them some definition while loosing weight. Finally, I'd make them narrow (Euro style).
Otherwise, go for it.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Bumper Pad
The back side has been milled out as much as possible and still have enough stiffness to stay flat. The Euro bumper has a different bolt pattern and is about half the size.
The advantage to these pads is you can always go back to stock since everything is bolt on. They can be painted to match the color of the car The plan is to produce them with the US version coming first. The time frame looks like two to three weeks and we will stick with the aluminum, T-6061, which could also be anodized to match the trim but that would be on a special order basis because of the polish and finish work required to prep the surface for anodizing . The standard finish would be powder coated in a black wrinkle finish and the wrinkle is very fine which looks almost like the stock pad. I will be contacting our Host to see if they have a interest in stocking them. I hope to have a picture posted today showing the pads mounted on a bumper. I can not use my own car because I have a Euro rear bumper> Go figure
Subscribed...
I also like the idea of tapering the protruding ends of them like the factory anchors; they are a bit too squarish now. Are these rubber-coated at all, or just a solid block of AL?
Waiting to see what they look like on the car... ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Bumper pad
I was able to upload a picture of the pad bolted to a extra bumper I have. The bumper that is on my car is a Euro model and the holes do not line up. I wanted to compare it to the OEM pad. The pad in the picture is a earlier version. The latest pad is .375 inches shorter and tomorrow a "Euro" bumper pad will be completed. I have also increased the bevel on the new version.
Weight is now under 1 pound for the Acetal including the studs and under 2 pounds for the aluminum. A reduction of 12 to 14 pounds. I have not weight of the euro version yet I will take some photos of them on my car as soon as possible. They are approx half the size of the pads in the last picture. I have been using Acetal, I hope I spelled it correctly, and aluminum. The aluminum is working out the best and cheapest
