I'm sure she's fine digger!!
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
grateful user
the muffller is held on by straps under the car, not those two bolts in the rear corner of the engilne compartment
Gary R. |
Welcome to the club... "Here's your sign"
![]() Many, many people here are in the, doing stupid things thread. Hope things go better the next time! Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Thanks for the replies.
If the shift rod is bent, what is the fix? Does the tranny have to be opened up? Come to think of it, it is a skosh hard getting into 2nd. The bonehead move was the result of my attempt to remove the a/c mounting bracket from the case. I'll post a pic soon.
Have you changed the engine oil yet? We get a lot of first time oil change disaster postings. Like using an 8qrt catch pan, when the engine and tank may hold 12qrts or more, etc. Good luck with it Matt!! Tony.
What all was "connected" when this motor hit the ground?
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Everything was connected and the motor didn't hit the ground. It dropped but stopped short of hitting the ground. |
