LinkBack | Thread Tools |
Rating: ![]() |
Throw it on the ground!
Any good tricks for removing speed and reference sensors from the mounting bracket?
I've got 1 sensor out and 1 stuck....REALLY STUCK. I will be replaceing them both so no need to salvage. I've tried PB Blaster and heat and no luck so far. Any good tricks before resort to I tearing up the offending bastige? BTW the one that's stuck is not the one protected by a tube.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
MBruns for President
I stick mine in a vice and banged with a hammer. I knew I was going to replace anyway.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Schleprock
Mangle the heck out of it. It doesn't matter since you're planning to replace.
Kevin L '86 Carrera "Larry" |
Stop! One of the sensors is in a sleeve and if you bugger up the sleeve you have to also replace the mounting assembly
edit- oops sorry- started typing before I finished reading. Last edited by charlesbahn; 11-19-2008 at 11:54 AM.. |
I just did this job and had the same problem. The one without the sleeve (Speed Sensor) just wouldnt come out. I took a hack saw to it to get past the soft cover, then I hit it from the back side with a punch and hammer to free it up.
I found I couldnt get the new sensor in either so I used the sanding bit on the dremmel to clean out the corrosion that was stuck to the walls of the mounts. Regapping the mount was the biggest pain, as the job requires at least 3 arms where only 1 will fit. Obviouslly the idea to put a 0.8mm washer on the end of the old sensor didn't work since I had destroyed it. I used a feeler gage which i taped tight into some neednose plyers. Be sure not to drop it into the bell housing of the transmssion!
1975 Widebody 911 3.2 Euro |
Definitely easier if you do it with a washer glued onto an old sensor. If you need one let me know I kept it and I'll loan it out as long as it is returned.
Charles Last edited by charlesbahn; 11-19-2008 at 01:23 PM.. |
Answer is there is no easy way to remove the sensor......21 years of corrosion and it was totally fused. I twisted off the plastic top and cut off the bottom of the sensor with a cut off wheel. There is a magnet rod in the core of the sensor that is encased in plastic that runs the entire length of the sensor. I was then able to punch out the magnet core then had to chip out the plastic and dremel out the corrosion. No way around it - it must be "mangled-out"! So much for my hope that John Walker would swoop in with one of his easy fix tips
![]() ![]() my journey continues ........ (targeting the week of Christmas/ New Year to complete the swap) ![]()
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 11-20-2008 at 08:56 AM.. |
Member 911 Anonymous
Caution! DO NOT TWIST in the new Sensor. It will break the internal filament liken to a stuck light bulb. If you break the filament your car will not start. Ask me how I know.
+1 there is no easy way to take out that Speed Sensor. The housing needs to be removed then the old sensor mangled out. Carefully press in the new sensor then use the moded feeler to get the proper gap. Of course easier with the engine out but no need.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
![]() ![]() The sensor mount is expensive. Anyone making a billet replacement? Len ![]() |
I would think a dismantler would be the way to go to replace a buggered mount.
Thread Tools | |
Rate This Thread | |
