Not taken the wrong way at all, thats why I keep posting, there is always someone who knows more about these things than I do...its great! ![]() 1. I am going to have another go at fitting the bonnet seal. I think the main problem is that the fibreglass bonner is thicker on the edges than the standard bonnet, hence the bonnet was sitting higher when it was all fitted. I have found a generic supplier of u-channel seal that I could use...for now i will keep the foam seal on the bumpers but I agree with the comments regarding the bonnet. 2. O'yeah...good point......erm...... ![]() Ok I have some options: 1- Leave as is as face consequences 2- Remove the carpet, paint over area and job done. 3- Rethink window mechanism... a- fixed glass with small window in window slider or flap opener b- recreate something like this 935 or 904... ![]() ![]() ![]() I think this is do-able, some aluminum u-section tapped with a drainage pipe and some custom brackets should do the trick? Thanks again Chris |
Hmm....935/904 slider is full height and may still have water entry issues..... maybe we should see how the factory did this, even if for rudimentary race duty.... if lower main window edge has a channel/tubing/collector, etc of some sort.
I was thinking more along a smaller portal....like here on posts # 2, #3 , #17, allows lower full edge to be sealed, of course this whole set up will let some water in thru the window itself to some degree, but you get the idea.---> 911 Slider Lexan Windows - Fixed Style
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 09-14-2010 at 12:39 PM.. |
Any updates?
Well I eventually opted for a 911 engine. I was hoping to have it fitted over the Christmas holidays, though sadly its still stuck in the UK due to bad weather etc. At this stage what's another few weeks
![]() ![]() 2.2e 911 engine, complete with Fibreglass tinware, RSR style bracket and also a pair of weld-in mounting brackets. It looks the part..... Chris |
I eventually got round to picking up some welding gas. First job was to make the seat bases.
I kept the original early slider bracket (on the sill side) and constructed a basic square frame, with additional weight saving holes drilled Clamped and tack welded in place... ![]() Finish the weld and clean up ![]() I got hold of some later sliders. They required alittle bit of drilling to fit the seat base, but now fit into the new frame and seat base a treat. ![]() ![]() Next job, tackle the central filler neck on the petrol tank Thanks Chris |
Dave Hanning
Hi Chris,
David in Portland here. I found some good "before pics" of the car on my computer, let me know if you want me to email them to you.
1975 Carrera coupe 1974 Targa 1998 Boxster 1999 Boxster |
Subscribed (better late than never)
Chris,
I love the height your car is resting at. Do you know the front and rear fender arc measurements? Sorry if this data has already been mentioned prior... Great project and attention to detail! Thanks, Steve
1967 SWB (Under Construction) 1992 Range Rover County |
"O Gruppe 13"
once again, I am glad to be here......Awesom job.
Gytis 89 964 C4 86 930 |
It would be great to see those pictures, I will send you my new email address. Cheers Chris |
![]() Sorry I don't know the measurements off hand, there was not an exact science involved I just adjusted it to what looked good. It will have to be adjusted and setup properly once the engine etc is installed, but it should be fairly close to what it is at the moment. If its any help the wheels are 16'' on 195/50 r16 tyres Chris |
Chris,
Thanks anyway. I sent you a pm with a couple specific questions regarding suspension upgrades. I guess depending on my tire/wheel combination I will have adjust to my preferred ride height. Steve
So I was kindly sent some pictures from David, aka 'earlyaircooled' of the car as it was when it arrived from California (California = no rust???).
This is how I bought it, what was I thinking! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Irony being, its now pretty much the same colour ![]() Chris |
Not the biggest job in the grand scheme of things...but its looks abit better than the length of wood, and also allows me to get the petrol tank in and out easier during welding
![]() ![]() Chris |
Dave Hanning
That was just surface rust.......right Chris?
I like the hood prop, another nice invention. Looks like primer gray may have been some inspiration for the color, good choice. All of us with this "disease" see the diamond in the rough....I have a bad case of it too.
Chris:
Me again....unless I am mistaken your seat bracket fab pics show the "L" shaped lever arm for fore/aft adjustment....to be on the tunnel-side slider of the driver's seat. Why?.....wouldn't it be better on the left-slider side, nearer the door? ![]()
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
![]() Its on the tunnel side so you don't catch it with your shoe while swinging your legs in & out. Len ![]() |
Yep, thats it. Good point ![]() Seriously though, theres no particular reason. Its far enough under the seat that it does not interfere with the gear stick or hand brake, yet it works fine. Last edited by jury; 01-19-2011 at 11:32 AM.. |
Funny....the factory then does it the "wrong" way.....
