Recreational User
Yes, I will definitely be reading Jeff's thread on his rebuild.
I love ITB's. I'd love to build a 3.2SS with PMO ITB's, twin plug, TEC-3, and S cams. If I can do that without busting my budget (including professional tuning), I wouldn't hesitate. Could an engine like that pass an emissions test? |
Call Orin @ 303.789.2545. He is great at getting hotrod engines through emissions.
Scott '86 911 Carrera Coupe, PCA, PBC |
Recreational User
Way too many options! Is mechanical fuel injection particularly expensive or challenging to implement? Should I even consider it? |
Slumlord
Get Bill V to comment on gear ratio's....and brakes.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
MFI is tough because it runs off a pump that is driven by a belt attached to one of the cam shafts. Obviously the non MFI motors do not have the attachment on the cam shaft. It can be added...its only money. There used to be a guy on here who had a 3.0 with MFI. I think he sold the car..very dreamy.
Also, I think the modern FI is such a huge step up in tuneability and ease of operation you would be better going after the "look" with some tall trumpets but actually using sensors and computers to fire the fuel instead of cam driven.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
careful on the 7:31 . the torque and use/ abuse ? will wear it out quickly. Better bet to keep the 8:31, wevo or similar billet side plate, and go with shorter gear sets.
we have had several clients (inc myself) bust or wear out 7:31's in high torque/ hp cars db
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Zink Racer
I posted this on another thread but hope this will help. 3.2 in my SC. I can tell you the driveability, usable torque, etc. is great.
![]() ![]() 1986 Euro Carrera motor rebuilt by Chris Powell of Chris' Foreign Auto in Bellevue, WA. Dyno tested at 210 SAE HP at the rear wheels. Adjusting for drivetrain losses and converting to DIN gives 255 HP at the crank. Rebuild details: 10.3:1 compression ratio Euro pistons and cylinders; low mileage 964 turbo crankshaft; 993 cams; cylinder heads ported and polished by Chris; case webs relieved for windage; ARP rod bolts; rods rebushed, balanced and resized end-for-end; pistons weight balanced; crank, flywheel and pressure plate balanced; throttle body bored out 3mm; intake manifold “ported” for larger throttle body and polished; injectors rebuilt and blueprinted; adjustable rising rate fuel pressure regulator; SSI headers with fully functional heat exchangers; new CV joints and axle shafts; Monty dual outlet muffler; Autothority chip customized for application. Some would probably argue the calculation on the HP conversion. I don't know enough about it to comment. This motor came with the car. If the criteria is to build your motor yourself, I would think this could be the way to go.
Jerry 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4, 1999 323ti |
Insert Tag Line HERE.....
buy the car on ebay and sell your car . that is a bargain!
My favorite is the 3.2L to 3.5L conversion carrera3.5L documented some time ago. California street car with 246 whp and 224 lb-ft of torque.
3.2 to 3.5 - Part II
Recreational User
Recreational User
Too bad you guys aren't located closer to me. It would be great to have TRE involved in the project. |
MBruns for President
Dude, I would be all over this... 964 3.6 Engine for sale
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
If, when, I do it again, I am going for more displacement. I am still toying with the 3.7 idea this winter but time is an issue for me.
From scratch, I would build a 3.9 or 4.0 with ITB's....... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Recreational User
I would like to have Todd at Protomotive convert the Motronics to a vac sensing system that would work with a set of Individual Throttle Bodies. Set it up with PMO units and get a set of early air cleaner tin to make it look stock.
Get a twin plug retro distributor and an Andial signal splitter. Maybe some and amber motor shroud. Could bore the cylinder, have them plated, and use J&E's unless some 3.4 or 3.5 MFI or Carb P&C's could be sourced. I'd also spend some of the money on the trans for some short gears.
This one gets my vote: 3.6L Race Motor, 350hp turn key
And after you buy it you'd even have some $$$$ left to play with...
I'm in heaven, when I drive my nine eleven... Last edited by RideShoot&Drink; 12-11-2008 at 08:58 PM.. |
Ask TRE about the RS clone motor they are building. It's probably a bit short on HP, but authentic for an RSR type toy.
