davemccorkle's Avatar
Update Ignition System
I posted a thread on twin plug or not and after much research I am not sure if it is the best thing to do or not.
Is there a plug / coil / ignition upgrade I could do that would get me almost as good as twin plugging?
2.7 RS 10.5 compression, very wild cams
Old 12-11-2008, 03:46 PM
Czar of C.R.A.P.
dfink's Avatar
back off the timing and run better fuel.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 12-11-2008, 03:56 PM
I will do that for sure but should I upgrade from the stock coil?
Old 12-11-2008, 04:21 PM
gtc gtc is offline
abides.
gtc's Avatar
It couldn't hurt, but it is certainly no substitute for twin plugging.
Edit: Steve Weiner at Rennsport Systems has a good explanation here (article #6).
Graham
1984 Carrera Targa
Old 12-11-2008, 04:51 PM
Dave,
The ONLY downside to twin-ignition on a 911 is the expense,.....
There are many benefits that include improved torque, quicker throttle response, cleaner running, and improved resistance to detonation. The latter item becomes much more critical when compression ratios exceed 9.7:1 on pump gasolines.
Without knowing all the details of your engine including what octane fuel you plan on using, I couldn't offer anything more specific,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-11-2008, 05:03 PM
I am starting to think twin plugging is the best thing to do. Thanks for the advice.
Old 12-11-2008, 05:23 PM
