| Go Speedracer, go! Join Date: Aug 2002 Location: Indianapolis
				Replacing A-arm bushings.  How hard is it?
			So, my significant other got a hold of my Pelican Parts wish list, and bought me some stuff on it.  Among those things was a front a-arm bushing kit.  It is called "Front Suspension A-arm Bushing Kit Set of 4, Poly-Graphite, 911/911 Turbo/912E 1974-89" in the PP catalog.  It comes with 4 poly graphite a-arm bushings.  How hard are these things to replace?  I am getting ready to replace the tie rods, so I'll have the front wheels off, but I never really researched this job when I added them to my list. I'm kind of obligated to replace them now, so I'm wondering what I've gotten myself into!
				__________________ 1981 SC ROW Coupe | ||
|  12-26-2008, 08:06 PM |
| Registered Join Date: Oct 2006 Location: Colorado, USA
			You should do a search.   They are easy to replace . . . if you do it improperly. But they usually don't work well, and start squeeking. To do it properly, you need to put the new bushings in their retainers, and then have it milled on a machine, to be perfectly round, nice fit on the a-arms. Also not a bad idea to cut some grease grooves in them. Done properly, they can give you a long time of quiet service. Since most don't have access to an industrial lathe, they use imprecise ways of "making it fit." Usually leads to squeeking/binding right away, or shortly thereafter. I think factory style rubber replacements, along with a tool and instructions, are now available. Don't know the price, though. I know for a street car, my preference would be stock style rubber bushings. They work fine for the street, no maintenance and if they last even 1/2 as long as the factory ones, you won't have to think about them again for a decade or more. | ||
|  12-26-2008, 08:13 PM |
| Registered |
				Front Suspension
			First off, I am not a professional mechanic and I am definitely not the smartest guy on this board.  However, I did it and it was easy.  I sent my front control arms to Elephant Racing.  They removed the old bushings and powder coated the A-arms (refurbished).  I then bought the Polybronze Bushings (PB) and installed them myself.  Re-assembly was easy as well.  With the PB you must spend a little more time to make sure the components are properly aligned or they will bind.  Get the PB you won't regret it. However, tread cautiously, you are entering the slippery slope of suspension trickery. I can not tell you how much money I spent on my suspension. I am affraid my wife might see this post and I cannot afford an attorney with the economy so slow.
				__________________ 1987 Carrera MoTec 3.8L Transplant, 993TT Brakes 2006 M3 Competition Package 2007 997 GT3 - SOLD | ||
|  12-26-2008, 08:40 PM |
| Max Sluiter |
			polygraphite DOES NOT EQUAL PolyBronze. PolyBronze are far superior. Polygraphite must be lathed to fit perfectly round or they will squeak. You must also cut grease grooves to lubricate them. The PolyBronze have zirks already. Polygraphite don't give as smooth a bearing motion as the PolyBronze. OEM rubber (which Elephant Racing will also install if you send the control arms) are basically maintainace free but are less sporty and derform in hard cornering.
				__________________ 1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance | ||
|  12-26-2008, 09:05 PM |
|  12-26-2008, 09:10 PM |
| Registered Join Date: Jul 2001 Location: mt. vernon Wa. USA
			An alternative is to install rubber bushings. Follow the link. rubber a-arm bushing question regards, al
				__________________ [B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ | ||
|  12-26-2008, 09:46 PM |
| Registered Join Date: Jan 2004 Location: Pittsford, NY
			any way you look at it, to replace the front a-arm bushings, the a-arms need to be removed.  While the bushings, at first glance, are inexpensive the time to do the r&r and the resulting alignment and corner balance can push the price up there.  If you intend to lower while you're at it, then do the rear bushings as well and only pay for 1 alignment and corner balance.  It certainly can be a DIY project, but not one to be taken too lightly and one that requires a bit of research before you start taking bits off. I would also recommend either a straight replacement of the a-arm with Elephant Racing for the rubber bushings or the ER polybronze if you plan to do it yourself.
				__________________ Tony G 2000 Boxster S | ||
|  12-27-2008, 05:16 AM |
| Registered Join Date: Sep 2003 Location: CT
			and you'll likely need to do the ball joints 'while you have the a-arms off'.
				__________________ 2007 997 TT 1992 500e | ||
|  12-27-2008, 05:45 AM |
| Recreational User Join Date: Mar 2004 Location: A Mile High
They won't deform in hard cornering, but they do deform naturally as the control arm travels through its arc of motion.  That's what they're designed to do, in the same way that the rear spring plate bushings twist (deform) as the spring plates swing about the torsion bar axis.
|  12-27-2008, 05:46 AM |
			You can also get the OEM rubber bushing replacement kit that Pelican sells, and do it yourself quite easily using the instructions and the video that ER provides.  The kit is inexpensive and the results will be far better than polygraphite bushings.
|  12-27-2008, 05:49 AM |
| grateful user |
			i bought the poly graphite ones, big mistake, i sanded, honed, lubed, cut in the grease groove and added a zirc, still popped and sqeeked, do youself a favor and dont use em, get the poly bronz, they are great.
				__________________ fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. | ||
|  12-27-2008, 06:36 AM |
| Registered |
This is a very easy install. The adapters that Chuck supplies with the bushings make it a cake walk.
				__________________ Steve Sapere aude 1983 3.4L 911SC turbo. Sold | ||
|  12-27-2008, 06:55 AM |
| Registered Join Date: Mar 2008 Location: Dayton Ohio.....Americas Playground!!!
			I just installed the "Other" ones from the other post and it was much simpler than I expected.
				__________________ 1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold  http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html | ||
|  12-27-2008, 07:34 AM |
| AutoBahned |
			"to replace the front a-arm bushings, the a-arms need to be removed." you could leave them attached at the ball joints whether that is a good idea or not is another question | ||
|  12-27-2008, 09:26 AM |
| Registered Join Date: May 2001 Location: Peoples Republic of Long Beach, NY
				 | mine have been in since pre ER days install went great after some fitting. 80k miles/no problems and no wear that I can find. no noise except on extreme suspension travel
				__________________ Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 | ||
|  12-27-2008, 09:45 AM |
| Registered |
			Yep, just bought the rubber ones( should receive them Monday) and I'll be installing them Monday. For the price you can't beat them($31). Kevin | ||
|  12-27-2008, 03:14 PM |
| Registered Join Date: Jan 2004 Location: Sacramento
			For me the largest cost was the alignment and corner balance after. Thus, do all the suspension work you want to do all at once. I just heated up the end of the arms with a torch and turned the stock ones over. Pice of cake and worked great and I now have more rubber isolating the weight than with replacement bushings. On my 85 there was evidence of the stock torsion bars starting to make metal to metal contact. I think with age rubber just flows away from the point of pressure. | ||
|  12-28-2008, 01:47 PM |
