orange911's Avatar
Need help finding Distributor washers
Any leads on how I can replace the little washers that the advance weights ride on? Both of mine were split and need replacing. Is this a critical component? I went to NAPA and they had a rebuild kit for the HEI dizzy and it had a teflon bushing with something on the bottom to ride on.
Regards,
Olin
1972 911T w/Carrera 3.0 - Light Yellow
1994 964 30 Jahre 911 - Viola metallic
Old 02-06-2009, 02:31 PM
Member 911 Anonymous
DRACO A5OG's Avatar
McMaster-Carr. http://www.mcmaster.com/
Order the stainless steel shims they are high heat resistant. You just need to match the ID or dremel for a snug fit.
The most important and impossible one to replace is the inner snap in bearing made of poly-blend. Ask me how I know.
'85 Carrera Targa
PCA/POC
Old 02-06-2009, 08:47 PM
