Need help finding Distributor washers
Any leads on how I can replace the little washers that the advance weights ride on? Both of mine were split and need replacing. Is this a critical component? I went to NAPA and they had a rebuild kit for the HEI dizzy and it had a teflon bushing with something on the bottom to ride on.
Regards, Olin 1972 911T w/Carrera 3.0 - Light Yellow ![]() 1994 964 30 Jahre 911 - Viola metallic |
Member 911 Anonymous
McMaster-Carr. http://www.mcmaster.com/
Order the stainless steel shims they are high heat resistant. You just need to match the ID or dremel for a snug fit. The most important and impossible one to replace is the inner snap in bearing made of poly-blend. Ask me how I know.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 02-06-2009 at 08:49 PM.. |
