How to Install Boxster Seats in an 74 911 (using original sliders)
There has been some discussion about installing Boxster/996 seats in an earlier car. The issue is that the seat sits higher if you use the Boxster/996 sliders.
I just installed seats from a 2000 Boxster in my 74 911 and I used the original 74 sliders, so they are at the same height. I got a really great deal on the black leather Boxster seats, so it was worth taking the time to figure out how to mount them.
The Boxster seats had manual height adjustment (pneumatic cylinder) and electric seat back adjustment. Yes, with the Boxster sliders the seats sat 1.5 inchs higher stock. It was noticeable and felt too high.
Here is how I did the install:
After removing the original seats, I ran a power wire from under the dash with an inline fuse. I ran a ground wire to one of the seat mount bolt.
Now for the seats.
Remove the Boxster sliders.
Remove the pneumatic height cylinder.
There will be the 4 pads that the sliders were bolted to. The front pads will have a lip that needs to be cut off. I used a high speed cut off wheel.
I took the sliders off the original 74 seats. The pads on the Boxster seats will have holes in them. I use the front holes on the original sliders and lined them up with the very front holes on the front pads on the Boxster seats. I used new allen bolts and lock nuts to mount the sliders onto the pads. You will have to drill new holes in the slider to line up with the hole on the pad.
With the original sliders installed the seats will line up with the original holes. The front bolts were easy to get to, the back ones were tight on room. I used allen bolts in the baqck and had to cut the allen wrench down to make it fit.
Here is a pictures of the seat installed.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 01-16-2009, 07:10 PM
looks very nice
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-16-2009, 07:52 PM
Make My Day
wowzer911's Avatar
cool, nice seats, are they comfy?
Not crazy aout that horn pad though.
74 911S Targa ROW
Building Designer/Business Owner
Old 01-16-2009, 08:57 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Cool idea - gotta' admit they look a little out of place (too "futuristic") in a '74, but they're undoubtedly comfortable. Nice job overall!
Black Cars Matter
Old 01-16-2009, 11:59 PM
Do you know if you can hook up the original heating element?
Old 01-17-2009, 03:28 AM
Thanks for the feed back. The seats are very comfortable, especially compared to the old ones, which were 35 years old. I use to have piles of crumbled foam under the old seats. I wanted a newer seat so I wouldn't have to worry about them deteriorating. I have to admit that I got the all black leather Boxster seats for $200 for the pair. I found them listed in "The Mart" section on the PCA website, which was the first time I looked there, my first source for used parts of course is the Pelican classifieds.
PorschePilot
MID9 Member
Old 01-17-2009, 11:54 AM
These seats didn't have a heating element. But since there is a 12 line to the seats, hooking up the heater shouldn't be a problem. The heater would draw more current, so a bigger in-line fuse may be required. I put in a 5 amp in-line fuse, which is fine for powering the seat back motors.
PorschePilot
MID9 Member
Old 01-17-2009, 12:06 PM
ShakinJoe's Avatar
I think they look great. Nice work.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 01-18-2009, 07:48 PM
Awesome work!! Nothing like actually being comfortable while driving...what a concept! I think the seats look perfect in your '74, not out of place at all. I see you are a Ford guy too.
Yasin
Old 01-18-2009, 07:54 PM
RocketWrench's Avatar
Send a message via Skype™ to RocketWrench
These are my current seats:
The are in great condition, but they are quite 'flat' and don't have any hugging quality in the corners.
I was thinking about replacing them with these:
Ill be keeping the originals, but here is the point that the purists here are free to abuse me....
Old 03-27-2015, 08:41 AM
marko's Avatar
PorschePilot,
What type of seat adjustments do you now have on the seats? Thanks.
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 04-02-2015, 11:25 AM
I have a bunch of 911 seat sliders laying around if anyone else is going this route.Nice job on the seats!!
Old 04-02-2015, 12:14 PM
I think they look great! nice job. Thanks for the write up, that's why I like this site!!!
Old 04-02-2015, 12:21 PM
The seat have the manual fore and aft adjustments and use the electric powered backrest, which is really nice for changes on long trips.
PorschePilot
MID9 Member
Old 04-02-2015, 12:57 PM
Great job !
Old 04-02-2015, 04:34 PM
