John-1977911s's Avatar
Quick Question Pertronix/Points (Ive searched
Hey Guys ~
Currently in the process of changing points to the Pertronix.
I removed the points & wire connector from the distro housing. Then ran the Pertronix black & red wires through hole in the distro housing, these wires then hook up to the coil.
Here is the question: What do I do with the wire the that was connected to the points outside of the distro housing? Tape it up??
Pleas help the sun is out... Thanks.
John D.
1977 911s Targa
Old 04-18-2009, 10:21 AM
This may help
http://home.comcast.net/~jrkengr2/html/pertronix_ignitor.html
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 04-18-2009, 10:42 AM
Thanks for the link - it still does not answer my question.
Dam!
Anyone else?
Thanks.
John D.
1977 911s Targa
Old 04-18-2009, 11:01 AM
If I'm correct, the wire of which you speak is for your Tach... Also, It may require that you contact Petronix for the answer as I remember when I had a 2.4 engine in my car, I had to call Petronix for the correct wiring diagram. Their number is (909) 599-5955 (They're located in San Dimas, CA) and probably not open until Monday.
Old 04-18-2009, 11:36 AM
What did you determine?
Old 04-28-2009, 04:58 PM
sean m's Avatar
Hey John.......did you get the Pertronix working or go back to points?
Sean M
'77 911S Targa Ice Green
Old 04-29-2009, 05:36 AM
