Folks,
I'm stocked up on parts and doing some final research as I prepare for some major suspension upgrades. I have a Tarett front sway bar that I plan to install. The drop links attach to a U bracket that you weld or bolt to the A-arm. Does anyone have any info on where/how you position U bracket in relation to the A-arm? Pictures would be a huge plus. Thanks, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Gordo -
I thought I had a photo of this, but couldn't find it in my library. I welded the "U" tabs on so that the thru-bolt runs front-to-back. Does that make sense? If no one else posts photos, I can take some of my car for you. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Schleprock
I've got a set of these Tarett brackets. With them cam a sheet of paper showing the install location/dimensions. I can scan it when I get home if someone else doesn't produce the information before me.
Kevin L '86 Carrera "Larry" |
SCWDP- Shock and Awe Dept
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Tarett U-Bracket Location
Thanks, the pics are very helpful.
KTL, PM'd you; appreciate if you could scan and send a me copy. The installation instructions that I have, don't provide any reference to the attachment location. I would like to attach the brackets and send the A-arm off for powder coating (exactly like surflvr911sc did), but need to know if I need to do a partial install of the sway bar to allow me to mark the location for the brackets before I remove the A-arms. Gordo
Schleprock
Gordo,
Here you go
I like the air deflectors, are those off of a 964? Thanks, Richard
1979 911 SC... 83 911 SC .... 82 911 sc.... Fiat 124 Spider Full Race Last edited by richard003@wind; 02-14-2009 at 11:01 AM.. |
A bit off topic but I think he has his u-tab question answered.
Here is the link to them in the PP catalog. (click on picture) ![]() This is them installed. ![]() ![]() You can see them hanging down doing their job here.
