cl8ton's Avatar
Tough question on stripped threads
All I seemed to have stripped some engine mount threads described in this post;
Stripped rear motor mount threads
I would really appreciate if anyone here could take a look and advise!
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 02-17-2009, 09:38 AM
Peter Zimmermann's Avatar
A Time-Sert should be OK if you use one with the correct depth, and there is sufficient material to hold the insert. A Heli-coil is also an option to consider. The torque spec for those bolts/studs is 35 lb/ft, so check with a local machine shop about each type of insert and what they prefer. Each insert requires a tool set for installation.
Keep the Shiny Side UP!
Pete Z.
Old 02-17-2009, 11:09 AM
