austin552's Avatar
Where can I get an oil filter housing seal?
Didn't see any here...
1974 911s
Old 02-26-2009, 01:43 PM
E Sully's Avatar
Try this part# 911-107-192-03-OEM
Old 02-26-2009, 02:14 PM
austin552's Avatar
Thanks but I need the seal between the filter housing and oil tank.
1974 911s
Old 02-26-2009, 08:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Isn't it on the filter itself?
'85 Carrera Targa
PCA/POC
Old 02-26-2009, 08:45 PM
Are we talking about the filter itself? If so, oil filters are typically considered consumables. I assume the easiest place to find another seal would be another filter. Just put the seal back on the new one when you are done with the current one.
1989 Carrera 3.2L in 993 bodywork
Old 02-26-2009, 08:49 PM
Max Sluiter
Flieger's Avatar
He means the big rubber donut thingy that the oil filter console attaches to the tank through. I need one, also. It was pinched, old, and worn out. To get it off, you must remove 3 allen head bolts behind the oil filter.
Old 02-26-2009, 09:00 PM
austin552's Avatar
The filter housing has a black rubber seal that seals it to the oil tank. I need that seal.
Found one. #18
http://dcauto.gotdns.com/illustration/index/455398927
1974 911s
Old 02-27-2009, 05:22 AM
Max Sluiter
Flieger's Avatar
Thanks for the link. #16 is what I need.
Old 02-27-2009, 03:29 PM
47silver's Avatar
seal
i purchased one from pelican...
911-107-192-03-OEM
61 bucks
1975 911S Targa
Silver Anniversary Edition
Old 02-27-2009, 06:59 PM
Max Sluiter
Flieger's Avatar
Actually, upon further inspection neither #18 or #16 appear to match the part.
Old 02-28-2009, 09:08 PM
