Almost Banned Once
If it's only surface rust then it should work out fine.
Take your time and if it all seems like it's too much work just focus on one smaller area at a time. Get that done and move onto the next smallish area. Before you know it you'll be finished.
If there is rust to remove why don't you use a wire wheel attachment for your grinder and get the glue , paint and rust off all in one whack? Home Depot sells one that has the twisted wire and that suckker will remove anything. My .02 worth.
Another Pelican and I have just gone through this and compared notes in the process. We both used brake cleaner and that worked well. It is discussed in these threads:
the plunge! My 911Spec build
1964 356 C 1970 911T 1974 914 2.0 1986 Carrera Spec911 race car #76 1990 Carrera 2 |
At the track = great day
I picked up the 3M adhesive remover and it does the job nicely. However I ran out of daylight so I've still have the driver's side to go.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
