Throw it on the ground!
HELP! Can't figure out how to remove the input shaft seal on a G50 gear box.
How do you get the old seal out???
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 05-08-2009, 01:25 PM
DO NOT accidently punch it into the case and then have to take it somewhere to have it removed.
Not that I've ever seen that happen.
Old 05-09-2009, 07:40 AM
jevvy's Avatar
I think i just levered mine out carefully although it wasn't as deep as yours. Could you try a seal picker?
A also then tapped the new one in too far and have to take the diff cover plate off to retrieve it which wasn't really too much ball ache.
'89 3.2/3.6 coupe
Old 05-10-2009, 01:22 AM
jevvy's Avatar
This is what it looks like when you pull the diff to retrieve the seal:
'89 3.2/3.6 coupe
Old 05-10-2009, 01:28 AM
Southern Class & Sass
Dixie's Avatar
Lots of cussing and patience is what you need. I cut a seal puller down so it would fit in the bell housing. That helped some. As I recall, the puller was of limited help. The hooked end was till too big to clear the input shaft. It did get the edge of the seal bent enough that I could get a small screw driver between the case and the seal. Once I could get to the edge, so light chiseling with a hammer and the screwdriver got the seal deformed enough that it came out.
That little seal is a PITA. Heck, it might just be easier to drive it into the case and then remove it from the shaft. Oh, and they all sit that deep. The guide tube has a ridge that goes into the case a bit.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 05-10-2009, 04:14 AM
kodioneill's Avatar
try screwing in a course thread sheet rock screw and pulling it out with a pair of diagonal cutters.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-10-2009, 04:29 AM
This is exactly what happened. I tried punching it gently just to break the seal hopeing I could then pull it out. Carnutzzz made me do it!
My friendly neighborhood mechanic was able to fish it out by snagging it with two hefty gauge puller hooks with T-handles. After snagging it and bringing back to the opening, a few sharp yanks and it was out. Nothing like a successful outcome when on the brink of disaster.
Mark
1987 911 Coupe
Old 05-10-2009, 01:07 PM
After reading these posts I am really scared. The RMS removal was a lot more than I bargained for. I have the input shaft seal already but have been burned more than once by fixing something that 'wasn't broke'. I may just leave this to a professional and bring them my G-50.
Old 11-06-2009, 02:44 PM
MBEngineering's Avatar
HI mthomas58
you would have needed this tool, but
and this to fit the new one,
regards mike
Old 11-07-2009, 01:04 AM
Originally Posted by MBEngineering View Post
HI mthomas58
regards mike
Now that's the right tool for the job! This thread brings back some bad memories. Here is the type of puller hooks that my mechanic used to snag the seal and pull it out. If the gauge of the hook is small enough you can slip two hooks on opposite sides of the shaft, snag the seal and yank it out. Of course by going down this path you are commited to replacing the seal as it will be damaged.
Assenmacher M0333 T Handle Puller Hooks - eToolDirect
Mark
1987 911 Coupe
Old 11-07-2009, 03:15 AM
Good news! There is one of these special tools available on eBay for $65. I just might have to pick one up to add to my special tool collection!
Porsche 911 Drive Shaft Seal Puller Transmission Tool:eBay Motors (item 110424418872 end time Nov-12-09 10:40:19 PST)
Mark
1987 911 Coupe
Old 11-07-2009, 03:37 AM
