Slumlord
G50 Issue - Monkey Needs Help
The Monkey is stumped.
First time with a G50 car and now this:P-car #2 ('89 G50 cab) has been sitting for about two years. After getting it started again I now find I can not get third gear when I am driving. Sitting at idle the G50 will go right into third no problem. I do not think this issue was there when I parked th car two years ago, I think it is related to the long time it spent idle. Not 100% sure of that though. I am guessing the synchro has jammed up (rusted while sitting?) and is preventing me from shifting 'on the fly'. I am tempted to drain the fluid and look for 'evidence', maybe put in new synthetic fluid and see what happens. Suggestions?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
I would say draining and filling with new gear oil (synthetic) is the right place to start. Otherwise I have no wisdom to impart...
Henri '87 Carrera coupe: Venetian blue |
Northern Motorhead
I replaced the fluid on my recently acquired 89 Coupe with Quaker State 75W140 synthetic and find it takes around 10 to 15 kilometers of driving before it starts to shift smoothly... After the oil warms up it shifts better than the original OEM oil !
Being from Canada there's lots of it at your local Canadian Tire ... lol |
As it only happens when driving I would look at the tranny mounts also. The oil change would be a (fairly) easy 1st step.
Gary R. |
Have you tried to put the car in 3rd, at idle, and drive away in that gear (from a stop) to make sure it really is in 3rd gear?
Please consider the above post about 75W/140 trans oil, that is not permitted for use in your car. You will be better served sticking with 75W/90 synthetic gear oil - I prefer Super Three Star Kendall synthetic, if you can find it in your area.
Keep the Shiny Side UP! Pete Z. |
Designer King
Let me know if you need some shop assistance.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Will it do into 3rd if you "double-clutch'? That would indicate if the syncro is good or bad....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
As stated above the 75W140 gear oil is not correct. 75W90 for sure.
You may also want to take a look at the shift linkage items circled in the diagram below. A problem with any of those could result in poor shifting. Items 2 & 10 are common wear items. Good Luck, Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 05-26-2009 at 08:53 AM.. |
Slumlord
I do not think it is a shifter, a mount, or a linkage issue. Pretty sure it's 'inside the box'.
Slumlord
So as of now:
- I can start in third, no issues there, third gear works from a stop. - I can not shift into third on the fly, even if I double clutch. I can feel the gears grinding if I try to force it. Prognosis?
Failing clutch fork or shaft?
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Slumlord
I do need a new clutch. All the 'action' is in the top 1/2".
Unrelated?
I would guess that if the clutch was the culprit other gears would be having the same engagement problem. A synchro can't fail while the car is sitting unused, but it could have been right at the point of failure when you parked the car. With your latest info I'll bet that the trouble is internal. Make sure that you have a good puller with a variety of different length jaws!
Schleprock
Sounds like badly damaged gear engagement teeth. If you can get them aligned when at rest, but cannot at speed, seems like the teeth are boogered. I have a hard time describing what the operating sleeve/teeth assembly looks like. It's not what most people recognize from the 915. The G50 Borg-Warner/Getrag gear engagement system is quite different in it's design
RE: clutch action occurring in the top 1/2, that's common. The G50 clutch engages really high on the pedal travel.
Kevin L '86 Carrera "Larry" |
Slumlord
I guess this winter will be G50 education time. Cha ching I am guessing for parts.
I can last the summer without third gear.
Just curious, how many miles are on the trans?
Given the symptoms, can you shift into 3rd on the fly by matching revs to speed? Coming out of 2nd, let the throttle off ever so slowly so the RPM's just drop off little by little. Keeping pressure on the shifter would allow the trans to engage in 3rd at the correct RPM to ground speed.
If this works, the trans is fine, the clutch is not. |
Slumlord
Lots. 150,000.
Probably a synchro, but I'll bet it costs lots less to fix than the clutch replacement. G 50s are over-engineered and almost bullet-proof, it might need nothing more than a couple of synchros/sliders.
Slumlord
My 964 G50 is exactly the opposite, all in the bottom 1/2, the way I like it.
